First post, by byte_76
I have ordered an AMD 5x86 P75 to buid a retro acarde game PC.
I have two 486 boards and I'm looking for advice on which one might be the best between them, if any.
Gigabyte GA-5486AL version 2.0
https://theretroweb.com/motherboards/s/gigabyte-ga-5486al
Gigabyte GA-486AM/S Version 2.20
https://theretroweb.com/motherboards/s/gigabyte-ga-486am
What are your thoughts?
Reply 1 of 7, by Yoghoo
Both nice motherboards. It's mainly a 100MHz/1024KB vs 133 MHz/512KB cache difference. Don't know how much memory you want to put in it but if you want to deck it out I would go for the GA-486AM. Else for the GA-5486AL.
Reply 2 of 7, by st31276a
The AM model with the umc chipset has nicer “vibes”
With 1M L2 you can cache maximum RAM.
Although, for arcade games you probably need no more than 16-32MB.
Reply 3 of 7, by PD2JK
The 5486AL looks cramped, but you don't have to replace or modify any Dallas/Benchmarq RTC module if empty. Hopefully it doesn't have battery damage.
I would also choose the GA-486AM, the IDE connectors at the bottom-right look clean.
But the best mainboard in terms of performance, I don't know. Maybe you can conduct some benchmarking. 😀
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 4 of 7, by kixs
st31276a wrote on 2025-03-07, 07:10:
Cache size isn't just for maximizing RAM size. Larger cache size usually also increases performance.
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 5 of 7, by st31276a
Yes that too 😀
Although, the effect typically declines as cache size is increased, especially for typical 486 applications.
Reply 6 of 7, by byte_76
There is some battery damage on the 5486AL but it’s only surface damage and hasn’t broken any tracks as far as I can tell.
The board posts and the keyboard works in the BIOS.
I haven’t tested any further yet.
I’ve ordered a new Dallas module for the AM board.
Yes, I’ll try to do some benchmark comparisons.
Which apps are recommended for those benchmarks?
I’m leaning towards the 5486AL.
Reply 7 of 7, by PD2JK
Phil's Dosbench is a good start I think, it has all sorts of benchmarking tools. Maybe you can post some results here, I'm curious.
