First post, by Kubik
Folks,
I wonder if someone has this drive in working order...
I have received it as a part of the IBM 5160 I purchased some time ago. The system looked like someone took all the period correct hardware and crammed it into the machine... One of those bits is the abovementioned YD-580 floppy drive. I tried it with more recent machine and while it kind of works (spins up), any attempt to access the drive results in some kind of "disk not present" or "drive not ready" error.
There are following jumpers available : DS0 DS1 DS2 DS3 HS HM with jumpers on DS1 and HS. There's unpopulated jumper (no pins) named RY that goes to pin 34 (?) of the floppy connector. I tried to short it but no change.
Then there's a set of 7 DIP switches marked "TM" with all of them on ON position. As the switch 5 goes to pin 4, I am guessing this also has some purpose...
Any thoughts?
Thanks a lot,
Kubik
