First post, by TeknoRider
Hello !
I have a Tulip X D 6/400 system (which uses a P2 400 Slot 1 w/ Tyan S1846 motherboard, 192Mb of Ram) that no longer displays an image.
I hadn't used it for a little while, but I know it was working before.
When I try to use it now, the LEDs light up, the fan spins, and the CD drive flashes/works correctly, but there are no beeps or image (the motherboard does have a beeper.)
I tried a lot of things:
- Leaving it running for a while
- Changing the CMOS battery, which was previously dead anyway
- Removing the RAM and booting without it, or with a single stick at a time
- Changing the AGP card to another one, booting without ISA cards
- Booting without the CPU, expecting beeps but nothing
- Unplugging the HDDs
- Using other PSUs
- Clearing the BIOS with the clear jumper
None of these steps changed anything, no signs of life aside from the power going through the components, fans spinning.
Do you have any more ideas or do you think at this point the only thing left are hardware checking the motherboard/capacitors ?
Thanks!
