First post, by DaveDDS
- Oldbie
Just letting anyone here might be interested knowing:
I've recently added the first released versions of DOS to my DBDOS
tool, this boots real DOS images, so you can experience what it was
actually like to run them:
I'm currently including the following:
Microsoft MS-DOS 2.11Microsoft MS-DOS 3.31Microsoft MS-DOS 4.00IBM dev. pre-release of DOS 1.00IBM PC-DOS 1.00IBM PC-DOS 1.10IBM PC-DOS 2.10IBM PC-DOS 3.00IBM PC-DOS 3.30IBM PC-DOS 7.1FreeDos 0.84Caldera OpenDOS 7.01Paragon Technology Systems PTS-DOS 6.51 (Russian)
These are the ones I've found so far which I believe to be available free.
I'll be happy to add others, but I don't really want to "fill it" with
DOSes that are currently available in bootable form from the vendors.
I've got a thread about DBDOS here: Re: DosBox BootfloppyDisk
** And yes, I do know that as it boots under DosBox - some might suggest
** this should be posted there - but this is more about early DOSes than
** how they are booted - I hope the admins will allow it here
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
