First post, by LSS10999
LATE EDIT: The issue that's blocking me from starting Win3.x on the system has been fixed as of VBESVGA v0.8.2. It's working fine now.
It was indeed caused by video cards doing weird things when setting modes, leading to unexpected behavior with Win3.x/9x DOS VM. The CRTC handling in VBESVGA has been adjusted in v0.8.2 to allow my system to properly boot WFW 3.11 in 386 Enhanced Mode, while on the Win9x side, SoftGPU VESA driver disallows DOS programs to set mode by default. This avoids the issue but instead requires all DOS games that need to set modes to start in fullscreen, or they will not run properly.
On the other hand, for Win3.x, AHCIFIX.386 is required if using SATA drives in AHCI mode. The driver can be used with Win9x but not 100% necessary compared to Win3.x.
Original OP for historical reference.
Context: (Solved) Trying to get Windows 3.1/3.11 working on a X99 system...
Right now I'm narrowing this down to a particular issue with my current system regarding DOS-based Windows (3.1 as well as 98SE), that I don't know if this is caused by BIOS (maybe SMM code) or some factors from other running hardware e.g. CPU or other onboard and discrete PCIe devices.
The problem is, whenever I try to launch Win3.1x in 386-enhanced mode, or trying to invoke VDM from Win9x (directly such as MS-DOS prompt, or indirectly by running a DOS-based program), the system would first freeze for 30 seconds, beep, then resume 10 seconds later.
For Win3.1 the system appears stuck after the control was returned (just that I could CTRL-ALT-DEL to reboot the system), but for Win98SE the system can continue operating without issues. In Win98SE's case, however, it can become a real annoyance if some installation process would run DOS-based programs multiple times in a row, as that will leave the system unresponsive for quite a few minutes with several beeps heard in between, though it won't cause any harm in the end if I'm patient enough.
I'm very new to low-level system debugging so I've no idea if it's possible to hook some kind of debugger on that system through its sole serial port (COM1) and see what actually was going on during the period when the system "froze, beeped, then resumed", as well as what might be the reason for the system to enter this "routine".
The following has been ruled out so far:
- At least for Win3.1, no difference between using IDE or AHCI modes for SATA. In both modes Win3.1 will end at a same point. It's just I need to load AHCIFIX.386 for AHCI mode, or it will fail at some other point before hitting this actual problem.
- Rloew's AHCI.PDR does not make any difference for Win98SE. This particular issue can happen with or without disk driver for Win98SE, and with AHCI.PDR things get worse, as it appears to be unstable with the system's AHCI controller, causing I/O errors that will register on the disk's SMART table. Win98SE will show a BSOD whenever such an I/O error occurs.
Some additional notes:
- On this system PATCHMEM (preferably with at least /M) is required for Win98SE to boot. Without it (and instead relying solely on LIMITMEM) the system will reboot during startup, with no relevant logs (e.g. BOOTLOG.TXT).
- Installing Win98SE with ACPI enabled (default) will cause many hardware entries not show up, including disk controllers. Need to install Win98SE without ACPI (by specifying /p i) to make them appear. Some system devices would appear with yellow exclamation mark complaining about no IRQ assigned to them, likely because they're in APIC territory, which Win98SE doesn't appear to support.
Reply 1 of 19, by doshea
I don't know anything about running old OSes on bare metal modern systems, so hopefully you get some better advice, but:
I wonder if the system is going to sleep for some reason? Are you able to disable the APM BIOS? I think this was something you could do on old machines, but I suspect you probably can't these days.
Yes, you should be able to debug over the serial port. I don't know if it would provide any useful information, but perhaps it's worth a try. I've never tried it myself, but I think that you should be able to either get Windows to just output debug messages as plain text, or allow you to attach a debugger which would use some debugging protocol (but as for whether the debugger would be more useful to you, I don't know). I think that you need to install the Windows SDK for your version of Windows, and then maybe it'll provide a batch file that switches to a debug kernel. You may or may not need to install the debug kernel - see below - but note I imagine it might blow away any patches you've installed.
MSDN mentions this from the Windows 3.1 SDK:
2.1.9 System Debugging Log Application (DBWIN.EXE)
System Debugging Log Application allows you to display messages produced by the debugging version of Windows, even if you are not running a debugger and if you do not have a debugging terminal. It even makes it possible for you to see some errors when it is running with the retail version of Windows. DBWIN.EXE allows you to control the output of specific varieties of messages. It also includes a feature that makes it possible for you to force memory-allocation errors, as an aid in testing the robustness of your application.
Reply 2 of 19, by LSS10999
doshea wrote on 2025-03-16, 03:31:
There's no way to disable those advanced features (e.g. APM and such), though APM doesn't appear to work with 9x at all, as I have to manually press the power button to turn off the system once "It's now safe to turn off the computer" appears.
It feels like some kind of very high priority interrupt that the system must process even at the expense of blocking* Windows during the period.
* I can still move my mouse pointer when it happens, but everything else stopped responding until the "routine" finished.
I think at best this could be used to debug Win3.x (386-enhanced mode) startup process. I'm very new to this so I need to look for some more documentation.
Just I don't know if there's any tool that can be used to debug while Win9x is running, as Win9x may not be as tolerant...
Reply 3 of 19, by doshea
LSS10999 wrote on 2025-03-16, 13:00:
Oh I see, that certainly doesn't sound like it's asleep. I seem to recall you can get beeping when the Windows message queue is full, which can occur if it freezes and you keep moving the mouse around, in which case it might beep every time the mouse cursor moves. Perhaps that's what you're encountering?
DBWIN is something you run inside Windows, and I think you should be able to leave it running, do stuff, and then come back and see what messages have appeared. See e.g. the last screen shot at https://diarywind.com/blog/e/install-debug-bu … d-of-win31.html - I don't know what the menus are since it seems to be in Japanese, but you can see some messages in English, and from the bottom right corner of the screen you can see that the desktop shows it's running a 3.1 debug kernel.
For startup issues you may in fact not be able to use DBWIN - you might need to set up the debug output to go to a serial port for that. Or maybe you can set it to go to a file - that DBWIN screen shot above seems to show an .INI file with an option for output to a file.
I'm pretty sure 98 will have something similar - the ability to have the kernel output some text messages indicating problems is surely not something that they would have removed after 3.x, as it's way too useful to Microsoft's developers.
If you can't figure out how to install the tools on whatever version of Windows or can't get them to work, please do let me know - if nobody more knowledgeable about them shows up, I'd be happy to give them a go, as I've always been curious about this stuff.
Reply 4 of 19, by LSS10999
doshea wrote on 2025-03-17, 06:35:
When it happens:
- OS stuffs stop progressing, but mouse can be moved freely.
- After 30 seconds, a single beep can be heard.
- Everything starts moving again 10 seconds after the beep.
Opening "MS-DOS Prompt" is guaranteed to trigger this. However, the opened DOS box works without issues after that "routine".
I just did a bit further testing:
- Running a 16-bit Windows program on Win98 doesn't trigger the issue. Actually, this system can run Win3.1 in Standard Mode without any issue, and the system never enters such routine in that case.
- Running COMMAND from inside the DOS box doesn't trigger the issue.
- Opening another MS-DOS Prompt while there are already opened ones will 100% trigger it.
- Running a DOS game inside MS-DOS Prompt does not trigger the issue, even if the game "requires MS-DOS".
So the question is what was happening under the hood when opening a "MS-DOS Prompt" on Win98. Perhaps it's some kind of BIOS/INT call misbehaving...
Additionally, when I was installing .NET Framework 1.1 SP1 update, after rebooting the system, this routine happened tens of times in a row, without any DOS box appearing. I think it was the .NET assembly optimization process and that somehow could trigger the issue whenever it runs...
Should point out the issue is specific to this machine. On another 865G-based system of mine, this issue does not occur and everything looks good there.
Reply 5 of 19, by doshea
LSS10999 wrote on 2025-03-17, 11:51:
When it happens: - OS stuffs stop progressing, but mouse can be moved freely. - After 30 seconds, a single beep can be heard. - […]
When it happens:
That certainly doesn't line up with any of the kinds of "normal" bad behaviour I'm used to seeing!
I can only hope that if you do some debugging you might see some complaint from Windows, or perhaps just an indication of what it was doing at the time.
I was wondering if Sysinternals' Process Monitor worked on Windows 98, but I don't think it'd be useful here - I think it would just show API calls made by processes, whereas what you probably need is some lower-level information about what Windows is doing that triggers the issue. I imagine Process Monitor might just show for example that explorer.exe started command.com, and perhaps it might say it took 40 seconds, but you already know that.
Reply 6 of 19, by myne
Feels like an overheat condition.
Try running... I forget the name, but "cool n quiet" was its descendent.
The problem with dos on new machines is it can't shuffle around to different cores and it likes to run flat out even doing nothing. So it could develop a single hot core and some sort of on die temperature gradient sensor could be freaking out.
I built:
Reply 7 of 19, by LSS10999
myne wrote on 2025-03-19, 12:22:
I don't think the CPU (or the bootstrap core) is overheating. The CPU is being adequately cooled, and the temperature readings from other OSes as well as in BIOS is not that high. Usually at around 30-40s.
Reply 8 of 19, by myne
That's one average reading.
What's that one core thrashing away at 5ghz at?
If it's 100c and 7 others are 25 that's 375/8=46. At that level of difference it's likely some core protection smarts kicks in.
Again, dos runs 100% all the time. Grab any old pc, sit it in the bios and the fans will eventually start winding up.
I'm pretty sure there's a small tsr that runs nops in dos.
It's worth a try
I built:
Reply 9 of 19, by doshea
Waterfall?
I can kind of see it being a temperature thing. I wonder if the BIOS settings might enable limiting the maximum CPU frequency? I sometimes do that from Linux when I want to keep the temperature down; not sure if BIOSes allow that kind of thing.
Reply 10 of 19, by LSS10999
myne wrote on 2025-03-19, 13:36:
Again, I don't think this is the case. I'm not overclocking the CPU so no, there won't ever be anything running at 5GHz there.
I'm using a 22-core E5-2699v4 on that system, and I don't think old OSes like Win9x would ever kick the turbo clocks. By default it should be running at around 2.4GHz.
And its HyperThreading has been disabled, because Windows XP can't handle more than 32 logical processors. I'm running a wide range of OSes on that system and everything is good except this odd behavior.
Regardless, I think I should give CPU-Z Vintage Edition a try to see if it can work on Win9x and whether it still supports reading newer CPUs, though it was a special edition focused on better detection of much older CPUs...
Reply 11 of 19, by myne
https://archive.org/details/dosidle
Can't hurt to try, can it?
I built:
Reply 12 of 19, by LSS10999
LSS10999 wrote on 2025-03-21, 12:20:
Just want to update on this... it doesn't work. Running CPU-Z Vintage Edition will lead to a crash with a BSOD due to something wrong with the VXD extracted by it.
Though the system can recover just fine with such BSODs at the moment. A long time ago, on older PCs as well as when Win98 was my main OS, such BSOD-laden crashes generally mean I have to do a hard reset.
Reply 13 of 19, by Jo22
Hi, maybe related to high CPU load? Always happens to me in VMs.
For DOS, I do use DOSidle. MS-DOS 6.x has power.exe, also, which can be repurposed. Dr DOS/Novell DOS 7 has idle-detection.
For Windows 3.x 386 Enhanced Mode, I do use WQGHLT by Weiqi Gao.
For Windows 9x, I do use AmnHLT.
Reply 15 of 19, by Jo22
Hm. I haven't used modern PC hardware for ages anymore (moved to Mac), so I'm not sure what to make of it.
Maybe there's a relationship with SMM or V86/VME of some kind?
The heart of Windows 98 is the VMM, Virtual Machine Monitor.
Windows 98 is like a V86 manager with a GUI, thus.
I wonder, is EMM386 being loaded in both cases?
It might make a difference for the better or worse.
Modern CPUs might have trouble with supporting A20 Gate etc.
If a V86 memory manager is loaded, the situation might be better, even.
Because with a V86 memory manager (EMM386, QEMM, 386Max etc), the state of real A20 Gate nolonger matters.
The memory manager is simulating it to applications (it itself needs full mem access after all).
Windows 98SE as a VMM should simulate it all the time, thus.
Reply 16 of 19, by LSS10999
Jo22 wrote on 2025-03-22, 14:09:
Hm. I haven't used modern PC hardware for ages anymore (moved to Mac), so I'm not sure what to make of it. […]
My BIOS does have some kind of A20 toggle, though I don't know if it really works, as the option was originally in a hidden Advanced menu that I managed to unlock without breaking the BIOS. The BIOS was quite delicate that many modifications such as replacing microcodes and such would render it non-bootable (stuck at particular POST codes).
I'm not sure how to load EMM386 correctly with a Win98 config, though I did see some localized Win98 versions (such as Japanese) have entries in CONFIG.SYS to load EMM386, without arguments but in some cases that worked.
In the past I never succeeded in making MS EMM386 and Win3.1/9x work together so I simply leave it out. Maybe I should give it a try just I don't know if it would properly cooperate with about 1.4GB of RAM. That's the amount of the RAM the system has, below 4GB boundary.
Reply 17 of 19, by Jo22
LSS10999 wrote on 2025-03-23, 04:32:
Hi, it was just an idea. It came to mimd because of AMD Ryzen, which had issues with Enhanced V86 (VME).
Then I also remembered that modern CPUs nolonger have an A20 Gate.
And since the issue appears when switching between DOS sessions, I thought it could be related.
That being said, the A20 Gate issue wasn't as big of a deal as it may seem.
MS-DOS 5 and 6 have no issues with A20 being permanently open or closed.
It's rather old DOS programs from the 80s that had used source code meant to run on CP/M, originally.
These programs, when ported to DOS, had used the 1MB rollover to access routines that are at the beginning of the address range. In simple words.
But once EMM386 or any other V86 memory manager is loaded, the real A20 Gate is left open (or closed, like a circuit?; dunno) and allows addressing Extended Memory past beyond 1MB.
At this point, the A20 Gate is being simulated to DOS and DOS applications.
Which even works on modern computers that have no physical A20 Gate anymore.
That's why I've mentioned it. But again, it's just an idea.
The problem could also be related to SMM (System Managment Mode) and stand-by functionality or power savings in general. I'm not sure to be honest.
Edit: Btw, I have a CD of Japanese Windows 98SE! ^^
I'm using it in a VM, to run Japanese emulators and games that don't like foreigners/foreign systems.
It's also great for reading Japanese documents and web sites that pre-date Unicode.
Works much better than just installing far-east fonts on modern Windows (XP and up).
The EMM386 was also installed in MS-DOS/V 6.2 by default.
To make all those language drivers of DOS/V fit into memory, I think.
Btw, you can also try QEMM 9 or a similar recent version, which has Windows 95 support (=Windows 9x support).
QEMM 7.5 and up supports VME, the Enhanced V86. Hence the "Pentium supported" sticker on some boxes.
So if your processor still has VME support, everything V86 related might be smoother.
MS-DOS 6.22 and Windows 3.x and WfW aren’t VME aware yet.
EMM386 isn'nt either, I think.
But loading EMM386 in DOS before Windows might have an efffect to DOS boxes on Windows.
EMM386 might still be suspended in background and become active when Windows 9x built-in EMM functionality isn't.
It's just an idea, though. The internals of Windows 9x are very complicated.
Each component is linked to another one, like a criss cross pattern.
Reply 18 of 19, by LSS10999
Just tested. Windows 98 can start fine with EMM386 loaded without any parameter, though the issue persists.
Thinking it might be related to SMM I tried disabling Legacy USB Support from BIOS but no difference, either.
SMM hasn't been ruled out yet, just that it's not caused by legacy USB's routine.
EDIT: I wonder if there is any documentation about what INT API Windows 9x's VDM would call when starting one... Probably one of those INT APIs used by Windows is responsible.
Looked at RBIL but couldn't find out which exactly would be Win9x's VDM (compared to WinNT's NTVDM).
Reply 19 of 19, by LSS10999
An update on this. It seems some discussions on the VBESVGA issue tracker shed some light about the possible cause.
In fact, I'm using an nVidia card (Quadro K6000) on that system, and from the discussions, it seems nVidia's VBIOS would touch CRTC registers in a way that would cause issues with VDD's emulations.
If I use VBESVGA's VDDVBE.386 instead of Win98SE's stock VDD, Win98SE would stuck and beep at the same place as Win 3.1x 386 Enhanced Mode, except Win98SE could handle the error a bit better. Instead of hanging like Win3.1x, Win98SE would show a "Windows protection error" about VDD after the second beep allowing me to reboot the system (or shut it down).
Tried fiddling with the newly introduced "BounceOnModeset" parameter (using only VBESVGA driver, with Win98SE's stock VDD), but for now it doesn't make any difference. Maybe it needs VDDVBE.386/VBEVMDIB.3GR to actually work.
EDIT: Just test the newly released SoftGPU v0.8.2025.53 preview driver, which added baremetal VESA support. It works, and this strange behavior does not occur there. However, the performance in overall is extremely sluggish for some reasons, comparing to VBEMP9x on the same system, as well as comparing to another system with SoftGPU and an AMD video card.
EDIT2: I've updated the OP as the latest VBESVGA v0.8.2 has solved the issue on that system for WFW 3.11 386 Enhanced Mode.
