First post, by majestyk
- Oldbie
I recently found this nice socket 7 mainboard but had to find out at least Ver.4 (and below) don´t support split voltage CPUs correctly.
So I did some measuring and made the necessary modifications.
Two traces need to be cut (red lines), Q6 - a TO-220 twin diode (non-schottky) plus heat sink have to be added and JP20 has to be replaced by a 3K3 resistor vor 2.8V Vcore.
No idea what the guys at Biostar did there, but the layout for D5 and D6 doesn´t make any sense at all.
On the backside one trace must be cut (red line) a bridge wire must be added and a pull-up resistor for BF2 can be added to detect 200MHz and 233 MHz Pentium MMX correctly.
