First post, by Imito
I never understood this because in the pentium2 and pentium3 era everything was simple and most of de cdrom drives were IDE already by that time
During the 90s the multimedia kits being sold used different standards to connect the audio card with the cdrom, like a sony 34pin, or Panasonic CD-ROM interface, or SCSI, or LMSI.
Most of the 486 motherboard did not have a secondary ide, and each company had its own connector. and the cdrom was connected to the soundcard.
For example
-mediavision PAS16 released different soundcards models where only one connector was available, one card LMSI, or one card with SONY or one card with SCSI, i think they never released one with IDE
-OPTi soundcards are very common and they included in the soundcard all connectors, sony,ide,panasonic mitsumi
-A good soundcard like soundblaster16 ct1600 came only with Panasonic CD-ROM interface, not IDE, so you can´t use it on a 486 with an ide cdrom?
So how do you build such combo now on a 486 computer? CDROM drives are not forever, most have died already, and some of those cards being sold cannot be used on a 486 computer?
or you have to watch out for a sound blaster model that has de IDE 40pin connector? Sure you can make the sound´+ ide cdrom drive work on a newer pc, but what about a 486 computer?
for example lets suppose you buy a mediavision pas16, with sony interface or a sound blaster card with Sony connector interface, if you can´t find a sony drive from the 90s you will not be able to have the soundcard+cdrom drive combo on your 486 computer?
or how do you do it now when you want to build a retro 486 ?
1) Using a ide cable with 2 connectors is possible?
2) is there a mod to do a sony 34 pin connector to ide 40pin connector?
3) Having an isa card with a ide 40pin connector and connected to the cdrom?
i always wanted to know this since as i mentioned, i mostly build PCs since the pentium2 era, but before there was too many variants and since those proprietary connections ended, and the cdrom drives died, you are left with a soundcard that cannot be connected with a cdrom drive to build a 486 computer?
Reply 1 of 6, by jakethompson1
Hard drive and CD-ROM on one IDE cable will work, however, it breaks 32-bit disk access in Windows 3.x. In Windows 95 it is fine. And on 486 and early Pentium systems, Win9x doesn't take full advantage of primary vs. secondary IDE anyway, because of bugs in the CMD640 and the like. That's the single fifo vs. dual fifo notation in the driver.
You can get ISA cards that are nothing but an extra IDE connector, that be not just secondary but tertiary or quaternary too if you want.
I would venture to guess that during the sound card CD-ROM era, CD-ROM penetration had not yet broken into 50% of systems shipped, but I would like to hear others' ideas on that. All hand me down systems I had used either ATAPI or no CD-ROM drive at all.
Reply 2 of 6, by fosterwj03
I bought a cheap sound card with an EIDE/ATAPI interface for my low profile 486 which only has 1 IDE port on the motherboard. The motherboard's port doesn't work with ATAPI drives.
My card is a MegaImage32 which has been discussed here on Vogons. It works great in my system with a Toshiba 12x ATAPI drive. If I had one complaint, the card's EIDE port is software initialized instead of set in hardware. You can't cold boot from a CD as a result.
Reply 3 of 6, by TheMobRules
When CD-ROM drives were introduced, manufacturers defined their own proprietary interfaces for the cheaper drives since there was no standard defined, but for the more expensive options they used SCSI which was well established by that point.
For a 486 if you want to use an IDE drive you have plenty of options:
  • On later PCI-based boards there are usually 2 IDE channels, you can just connect the CD-ROM drive to the secondary
  • If your board or controller card has only 1 IDE channel you can connect the drive as a slave on the same channel with the HDD as master (this is what I did when I got my first CD-ROM drive in 1995). This will limit the performance of your HDD but given the speed of a mid-'90s IDE hard drive on a 486 it wasn't a major problem
  • You can always get one of those EIDE cards which allow you to add a secondary IDE channel
  • Get a sound card with an IDE connector
By the way, I have 3 drives with the old proprietary formats (1 Sony, 1 Panasonic and 1 Mitsumi) and they all work perfectly. They require some care (capacitors on the Sony and gear replacement on the Panasonic) but otherwise they're solid, the lasers work great (they even read CD-Rs) and they are ideal for early CD-ROM games unlike those cheap chinese no-name drives that started to flood the market during the mid to late '90s and sound like a plane about to take off.
Reply 4 of 6, by Imito
TheMobRules wrote on 2025-03-17, 03:13:
When CD-ROM drives were introduced, manufacturers defined their own proprietary interfaces for the cheaper drives since there wa […]
thanks for the details
From the options list you gave me i was more interested in a soundcard with IDE interface, sadly very few good SB models have it CT2290 , CT2830 and CT2910 and if i was rich a ct3900
if i don´t get one of those then i will have to find a EIDE card, can you recommend me one any easly found on ebay? so i can use a good old CT2230 without any ide cable on it.
Reply 6 of 6, by chinny22
Our first PC was a 486 with a Panasonic interface drive off a SB16.
When this drive died, we got an IDE drive as it had become the standard.
but I found once we had a large hard drive (at least 4GB) and networking setup I didn't really need a CD drive anymore.
As long as you partition your hard drive with at least OS and drivers to get on the network you can then send any other files over the network rather than CD.
and the speed benefit from applying no-cd patches to games is also beneficial.
