First post, by Broifonn_9
So, I set up a Windows 3.1 install on 86box using a 386DX machine (specifically the ECS Panda 386V). The version of 86box is 4.2.1
The specs are: 16 MB RAM, 386DX 25 MHz, VGA, serial mouse, Sound Blaster 1.0, PC/AT IDE controller as HD controller, 32 MB hard drive, internal FD controller, and 1 3.5" 1.44 MB floppy drive. Win 3.1 is installed under DOS 6.22.
I've got a little problem when trying to start up Win 3.1. So, when I type "cd windows" and type "win", and I press enter, the logo is shown (around 2-3 seconds), and after that it instantly reboots, but not as a soft reset, but a hard reset (e.g. the amount of memory is shown)
I tried launching Win 3.1 on another 386 motherboard, another non-386 motherboard (486, for example, and it still reboots). Tried to use a CD-ROM instead of floppies. Didn't help. And I tried to use DOS 5.00. However, it works on VMware.
Is there any problem with my setup? Or is it just Win 3.1 that doesn't want to start up on 86box?
Reply 1 of 8, by Broifonn_9
Edit:
This works on a Pentium machine (I chose the random one). Weirdly, Win 3.1 can't boot on a 386/486, even though it was designed for these CPUs.
Reply 2 of 8, by SA1988
Use a newer build of 86box.
Reply 5 of 8, by GemCookie
I can't reproduce this on 86Box 4.2.1 with an identical configuration.
Are you enabling 32-bit disk access? Windows 3.1 rarely works properly with it.
Gigabyte GA-8I915P Duo Pro | P4 530J | GTX 750 Ti | 2GiB | 120G HDD | 2k/Vista/10/FBSD
MSI MS-5169 | K6-2/350 | TNT2 M64 | 384MiB | 120G HDD | DR-/MS-DOS/NT/2k/XP/OBSD
Dell Precision M6400 | C2D T9600 | FX 2700M | 16GiB | 128G SSD | 2k/XP/NBSD
Reply 6 of 8, by Broifonn_9
SA1988 wrote on 2025-03-17, 12:41:
I've found 86box 4.3, installed roms and made the identical configuration.
And... it works. So maybe it was the bug of 86box of that specific version.
I guess the problem has been solved.
Reply 7 of 8, by Battler
Build 6105 was a nightly build of 4.2.1 - I think this was fixed by 4.2.1 stable (build 6130).
Reply 8 of 8, by Jo22
GemCookie wrote on 2025-03-17, 16:52:
Hi! The Micro House driver is quite stable, works with IDE HDDs up to 8GB.
http://win31.de/edrivers.htm
