First post, by stealthjoe
I am trying to set up this card under Win 98. However running into a few quirks. First, the card gets detected as DMA 0,3 with IRQ 5 at BIOS. After instaling the required VxD drivers under windows, there is absolutely no sound output under 98. However, there was sound output in DOS. Then I went into BIOS and changed the PnP/PCI config to manual and set the DMA 0 to ISA reserved. Then the card was detected at DMA 1 and the sound was working in 98. Using automatic config, the DMA is stuck at 0.
Trying to understand why the DMA would get auto assigned as 0 under BIOS as I didn't face this issue with 2 other YMF 719 cards. Are there any jumper settings that need to be adjusted on the card? There seems to be 2 jumpers beside the line out plug in the 1-2 position. Could someone please share their experience with this card?
Intel 845GEBV2, Pentium 4 2.4 Ghz, Geforce FX5600 256MB, 512MB RAM, 160GB HDD, Sound Blaster Live! SB0100 - Win 98.
