First post, by zb10948
- Member
Hey,
Are there any trackers that work on XT/SBPro?
Hey,
There's GLX https://www.pouet.net/prod_nfo.php?which=73182 https://hornet.org/music/programs/players/glx212.zip and... freddyV's program... name eludes me atm... looking it up
edit: Mod Master XT
more info GLX Player the only XT player ? Check Mod Master...
Do not ask Why !
I'm using Mod Master XT on a Commodore Pc10 with NEC V20, VGA, SB 2.0, 640KB of RAM, 64KB UMB memory and 2MB of EMS.
Sampling rate is about 6 KHz, which works without stuttering.
Playback via Covox Speech Thing also works at that sampling rate on another 4,77 MHz V20 machine.
Thx guys but I already use Mod Master XT...need a tracker, not a player.
Hm. Tetra Compositor ?
Tetra Music Compositor.
https://www.youtube.com/watch?v=LpypDIkOm4g
ModEdit (versions 1.00, 1.10 and 2.00) by Norman Lin should work on a XT, but it uses MODRES.COM to play the music which requires a 10 Mhz or faster CPU.
You can use ModEdit on a XT to compose the music but to play it you need Mod Master XT.
