First post, by meme
I'm running GNU/Linux (Athlon 2500+). I've installed DOSBox ver. 0.63 and Qemu 0.70. For fun, I made full win98 installation with qemu. Qemu has incomplete sound support, but in DOSBox sounds work ok.
Now, when I run win98 with qemu, and try to play DOS games, they run just smooth! A lot faster than with DOSBox! Qemu running win98 is in speed comparable to a pentium 2, even in DOS mode.
Qemu version I'm running is full GPL'd code, so I thought you could look at it, if you could use something of it.
DOSBox in general is fine, I ran Cannonfodder and Assault Trooper just ok, but Liero and Tapan Kaikki run slow compared to Qemu.
Qemu homepage:
[url]http://fabrice.bellard.free.fr/qemu/[/url]
Reply 2 of 3, by meme
I'm using only the GPL'd part, 'cause proprietary kernel modules do only irritate and are hard to get working (proprietary nvidia drivers are missing too.)
So, I run full in userspace. Machine is Athlon 2500+, 512KiB L2, 256MiB RAM, 266MHz FSB.
Comparing DOSBox and Qemu is meaningful, because both do full hardware emulation.
Reply 3 of 3, by wd
Rank DOSBox Author
DOSBox Author
Well then use Qemu.
