The Main Three (Retro PCs)
First post, by Orzene
Current main 3 PCs for different eras of classic gaming/programs --
IBM ValuePoint PS/2 433DX --
Motherboard: IBM PS/VALUEPOINT 6384 board
CPU: Intel i486-DX2 66mhz processor
Graphics: Tseng Labs 1mb video chip (integrated)
Audio 1: SoundBlaster 16 PRO PnP (CT2980) sound card (for CD-Rom support)
Audio 2: ESS AudioDrive 1868F 16-bit sound card (Main audio)
Memory: 16mb (4x4) Goldstar GMM794000S-70 30-pin sticks
Storage: IDE-to-CF 2gb card (1gb partition)
Win95 PC
Motherboard: DFI P5BV3+/E (REV.:B) (VIA chipset) Baby-AT board
CPU: AMD K6-2 400mhz (MMX, 3DNow)
GPU1: CIRRUS LOGIC CL-5446 (Rev 0) 2mb PCI video card
GPU2: Diamond Multimedia Monster3D Voodoo1 4mb accelerator
Audio: OPTi 82C924 Crystal Dynamics audio card (original OPL3 and Crystal CS4231-KL chips)
Memory: 256MB Ram
Storage: IDE-to-CF 16gb card (2gb Windows partition/12gb program partition)
Win98 PC
Motherboard: (Easton) Intel D815EEA board
CPU: Intel Pentium3 Coppermine 1000mhz processor
GPU: AMD Radeon 9550XL 256mb AGP card
Audio: Creative Labs SoundBlaster Audigy2 ZS (SB0350)
Memory: 1024mb (512x2) PC133 Low-Density SDRAM
Storage: IDE-to-SATA WD Blue 2.5 250gb SSD (4gb Windows partition/64gb program partition)
Peripherals/Accessories:
Microsoft Sidewinder 3D Pro (2x)
Microsoft Gamepad (1x Gameport/1x USB)
IBM Computers Model M Keyboard
Perixx PS/2 Optical Mouse
TRIPP-LiTE KVM switch (VGA/PS2)
MegaTOOLS Kramer scaler box
Notes:
I originally had a mechanical VGA KVM switch for the Voodoo1/Cirrus Logic card, but it started to fail (causing colors to become "off"/yellowish). I switched back to a Voodoo pass-through cable, and that seemed to fixed the issue. I've come to realize that the mechanical KVM switches are a little flimsy, and so I'm looking at sticking to digital KVM devices from now on. I also still own that Voodoo3 PCI card that I posted about some time ago when it stopped properly working with my Win98 machine. I may break it out and test it again to see if it like the DFI board sometime in the near future.
An issue with the Win95 machine has been mainly with stuttering when reading CDs, as well as the fun bit where Microsoft game peripherals don't seem to like the PC (Tigershark in particular has refused to respond properly to either my Sidewinder 3D Pro AND/OR my Microsoft Gamepad). So it's either I switch to a different PC to use a desired peripheral, or look into different peripherals entirely.
Originally the Win95 PC came with a ASUS P5B-A (Rev 1.05), and it came with a Pentium MMX 233 (I have that in storage right now) - I switched to the K6-2 400mhz, but it didn't recognize it properly, so I had to set it to 350mhz instead. This worked for a time, but I began to wonder if having the Pentium 233 would be better. I swapped the chips and changed the jumpers, but after I did this, the board stopped posting altogether. I swapped back to see if it was the CPU, but I still go no post. The P5B-A is currently in a static-free bag and is currently shelved for now, with no idea what I want to do with it. The DFI board is running nicely (enough), though I have considered trying to switch back to the Pentium MMX 233 again.
The reason I use the SoundBlaster 16 for CD-Rom support is because the IDE connection on the ESS card isn't recognizing the CD-Rom. Since I had a free ISA slot, it wasn't a big enough deal to do further testing to figure out the IDE issue (yeah, a bit lazy on my part - I wasn't in the best mood that day). It has had no issues with audio or IRQ conflicts so far.
The Win95 machine's background was made in Blender 2.49 and then had its color bitrate reduced in Jasc Paint Shop Pro 6.01 (the version I use ACTUALLY RUNS in Win10/Win11 with just a registry error)
Reply 1 of 22, by Orzene
I don't know why the IBM Valuepoint is showing as a 486DX instead of a DX2 - Any games that run diagnostic programs show it as a DX2 66mhz processor.
Reply 2 of 22, by wbahnassi
Probably an unsupported upgrade. The original IBM BIOS doesn't know of the DX2 and identifies it as DX. Shouldn't matter perf-wise. You can try updating the BIOS and it might recognize the CPU properly. This kind of behavior is very common on OEM machines which don't expect users to meddle with the machine themselves. It's one of the reasons why I like to stay away from OEM builds.
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
Reply 3 of 22, by Matth79
Why 95 & 98, is there anything for 95 that doesn't like 98? I was expecting DOS, 98 & XP
Reply 4 of 22, by SScorpio
What are you using the 486 for that a K6-2 or the 233MMX can't do? Your CL-5446 and Diamond Voodoo 1 are the exact cards in my DOS era build. I run a 233MMX and can slow it down to 386 speeds to run Wingcommander without issue.
Your Win98 machine overall looks good, but you have a big gap going from a Voodoo 1 to a Radeon 9550XL. The Voodoo 1 had some support in the early version of Direct3D while the Radeon is on the tail end. So there are quite a few games in the Direct3D 6-8 era that can have issues on the Radeon. If you don't play any, that's fine. But something to think about.
Those do look like fun, and I'm sure you can squeeze an XP tower in there two with a little shuffling.
Reply 5 of 22, by Orzene
SScorpio wrote on 2025-03-22, 15:44:
Matth79 wrote on 2025-03-22, 15:03:
A WinXP machine will come later, since I have two ASUS boards that I can mess with, in-box, and with their respective components. I just need a proper Case, PSU, and Fans.
Reading posts on VOGONS, some people would kick Win95 to the curb. That's fine.
For me, it's preference/nostalgia. My first windows PC was a Win95 machine, but it was also a bog-standard PC that barely ran some 3D games in Software Rendering. I don't mess with any CPU clocking, so the slower 486 is there as a separate machine for games that are speed sensitive. I also really love my Sidewinder 3D Pro, which despite my best efforts, utterly hates my '98 machine (see:" Odd Issue with SideWinder 3D Pro in Win98 "). So I use it primarily on my '95 and 486 machines, with games like Fury3, Hellbender, Wing Commander: Privateer, and Descent (It works pretty good in DOS).
Yeah, the 9550XL leaves a pretty big gap between it and a Voodoo1. If anything, with the tests I've done it's a decent early XP GPU, with the 1000mhz Coppermine, and I'm considering making a second partition for XP on that machine. However, with the Win95 PC, it does at least feel authentic to a system that would run early 3D games like POD and Interstate '76 in Glide. I have a Voodoo3 PCI card, but it isn't being used (since my 98 machine stopped accepting it, and I haven't gotten an AGP variant just yet). To be frank, I probably should have aimed for a weaker card to stuff in there (if I ever do get an AGP Voodoo, that'd be cool - Or maybe even an early NVidia card might be neat), so that's on me.
wbahnassi wrote on 2025-03-22, 12:37:
I've considered making a 5x86 DOS PC, too, with a proper VLB-supported board, because of that weird technical niche between it and early PCI. I might do that some day. The 433DX was bought from a newspaper publisher for $5 (along with the '98 PC, it was $10), so I'm enjoying the heck out of it while it still works. From my research, updating the BIOS would be painful, so it's stuck as it is.
Reply 6 of 22, by Orzene
Alternatively to what I said earlier about making a 5x86 machine, I could go backwards and make a 386. However, I still want to seek out and build a VLB system, that weird little niche stepping stone between ISA and PCI. It probably won't be as interesting, performatively, when in comparison to doing something like making a first-gen Pentium/486DX4-100, but I'm okay with that. It's just an interesting little bit of tech, same as the 3D API's that existed before DirectX and OpenGL became the standard.
As an aside to the mention of WinXP machines, here are my board options:
ASUS A8N-SLI Deluxe
BIOSTAR N4SLI-A9
Hopefully this is fine as a part of this thread, since it isn't about the "Main 3" I listed up above. I'll keep things directed to those after this post.
Reply 7 of 22, by Orzene
Keeping on topic -
The Windows 95 Machine:
The one thing that I'm having issues with is that, unlike the P5A-B v1.5 board, the current board seems to be having issues with the Microsoft Sidwinder 3D Pro and Microsoft Gamepad.
With older games/DOS games, the controllers seem to work fine. Fury3, Hellbender, and Descent 1&2 all seem to work fine. However, anything else I've tried doesn't like these controllers, or barely registers inputs from them ( Final Fantasy 7, Tigershark, and Interstate '76 to name a few).
So far I'm still fiddling with the system, playing with drivers to see what will get them to work. I've tried underclocking the CPU from a K6-2 400 to a K6-233 to see if that might make things better, and have a PCI audio card with a gameport to see if it might be related to my ISA audio card. No luck there, unfortunately.
I -would- say that it's an issue where the Diamond Multimedia card is interfering with, then I don't know, but if Hellbender accepts it fine while running with Glide, then my thought is that that isn't the issue.
It'll probably be fixed with drivers, but if anyone has dealt with this sort of bizarre issue, let me know.
If I get it to work, I'll update the thread with a post explaining what I changed, and hope that someone else finds it useful.
Reply 8 of 22, by Orzene
The IBM Valuepoint PS/2 433DX --
I'm still thinking on replacing this with a 486 built from the ground up. I want to keep my DX2-66, but I'm wondering if a Socket 3 board wouldn't be out of the question. I really do want to get into VLB with a 486 machine, and maybe have a swappable CF card with Win3.11 on it. Since these are my first dives into vintage PCs (not great timing on my part, considering the bloated pricing of hardware these days - if I could go back in time, I think we all would want pre-2015 prices)
If I could find a decent board that fits the case, that'd be pretty cool! It uses a Riser card, and finding VLB-Riser cards isn't particularly easy, so the whole base system might have to go. I have to do a solder job on the coin-cell seating since the clip arm broke a while back; which I have a replacement for that entire seat, so it's just getting the kid and matte, then just going through with the work.
I've seen some PCs in the Valuepoint line for sale around, some of which have VLB support, and I could probably rip and swap to get the desired machine.
If anyone has tips on a Socket 3, or if Socket 2's are a better match, I'd appreciate the advice.
Reply 9 of 22, by bZbZbZ
Orzene wrote on 2025-04-27, 05:31:
Yeah that sounds like period-correct Windows 95 era headaches! My first childhood PC was from that era too (migrated from Mac OS 7.1 to Win95) and I remember the senseless I/O, game controller, driver troubleshooting... I recall that the order of device driver installation would sometimes impact functionality in edge cases... and the only recourse was to re-wipe or re-image the drive and start over!
Do those two peripherals work okay in your Win98 machine in those problem games? I don't blame you for having a Win95 machine though... I have nostalgia for Win95 too (although I'd admit that Win98 is mostly better in every way except system requirements).
Nice systems by the way!
Reply 10 of 22, by chinny22
Everyone needs a 486/66 and the fact it has the highly regarded ET4000 onboard makes it pretty special.
But I also think you need either a 586 133 or POD in which case may as well find a VLB system to install it in 😉
You could then either remove the 2nd card from the IBM or get a Yamaha YMF soundcard and have the main 3 soundcards represented.
Much like your IBM, you may be better off looking at OEM systems with an integrated VLB video card then trying to build from scratch.
Benefit of desktops is you can stack them as well.
Personally I don't see the need for anything earlier then a 486 (truth is even 486 isn't strictly necessary) unless your playing a game with specific speed requirements.
I recently scored a 386 DX which while nice, think I'll end up selling as will almost never get used.
Reply 11 of 22, by Intel486dx33
This was the Case I used back in 1998
I had a AMD K6-300 in it at first
And then upgraded it to a Pentium-II
Enlighten Computer Case.
They were inexpensive and popular back in Win98 era.
Reply 12 of 22, by Orzene
Intel486dx33 wrote on 2025-05-06, 14:20:
This was the Case I used back in 1998 I had a AMD K6-300 in it at first And then upgraded it to a Pentium-II […]
It's been pretty solid! My only complaint so far has been the drive tray backets - Not the biggest fan of them, especially if you accidentally set them up backwards. But, for the price I paid for these computers, it's a small thing.
(Also, the open bay was going to be where I had the Audigy ZX control panel installed, but finding the proper cable to connect it to the card has been next to impossible. Not sure if there's a good alternative out there that people have used as a substitute.)
Reply 13 of 22, by Orzene
chinny22 wrote on 2025-05-06, 02:44:
Everyone needs a 486/66 and the fact it has the highly regarded ET4000 onboard makes it pretty special. But I also think you nee […]
I don't believe integrated video chips have the same power as a proper VESA local bus bridge? - But feel free to correct me on that one. The problem with this particular OEM machine is that it can't expand beyond a DX2-66mhz processor, and it doesn't have any VESA local bus support (as far as I can tell), so physically, I'm stuck with just ISA slots. UniVBE seems to work alright, though. It'd be nice to look at something more customizable than a Valuepoint 6384 board.
As far as a 5x86 CPU goes, it -IS- tempting, but I'm not sure I want to go that direction just now, though I am on the look-out for a good Socket 3 board, at the very least. The DX2-66 feels like a powerful enough CPU to handle most DOS games (excluding Descent 1 and Duke Nukem 3D, in my experience). I -AM- curious about something, though; Can an IBM VLB Riser card work with any old board with VLB slots that you attach it to? If so, then I can skip getting a new case and just keep the old one with the already-installed PSU.
Also, having a 3rd audio card installed? .... Oh my! 😁
Reply 14 of 22, by dominusprog
Orzene wrote on 2025-03-23, 17:41:
As an aside to the mention of WinXP machines, here are my board options: […]
BIOSTAR N4SLI-A9
If you have any plan to use the Biostar board, do a recap, especially for the VRM bulged caps.
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 15 of 22, by chinny22
Orzene wrote on 2025-05-09, 00:03:
This shouldn't be the case, at least during this era.
It's true onboard devices on more modern motherboards were more intergrated using CPU and RAM resources.
But Socket 3 onboard devices only shared the same silicon board. each component still had it's own resourses not shared with anything else.
So the only difference between a onboard VLB vs descerte video card is lack of a slot.
Agree any game that doesnt work on a 66 isnt going to work on something faster. Going faster only really helps impove existing games, e.g. larger maps in Doom 2
I doubt that a VLB Riser will work on a non VLB system as most likely the motherboard/chipset lacks any VLB subystem. Just as adding a riser with a PCI slot doesnt magiclly give you a PCI bus.
Looking at the list on Wiki VLB systems typically had video from S3 or Cirrus Logic, one of those motherboard's may fit your case though?
https://en.wikipedia.org/wiki/IBM_PS/ValuePoint
Reply 16 of 22, by Orzene
dominusprog wrote on 2025-05-09, 00:15:
BIOSTAR N4SLI-A9
Thanks for pointing that out! The thought never even crossed my mind, sadly. I don't have the setup for soldering right now, and I'll need to practice a bit before hand, but I'll give it a shot in the future. At least they're pass-thru connections.
The Biostar is actually my 2nd choice between the two I posted. The first is the ASUS SLI board, which, most of the caps look to be in pretty good shape after I gave it a looking over.
Reply 17 of 22, by Orzene
chinny22 wrote on 2025-05-09, 06:18:
I should have clarified that what I meant was; if any mainboard with a VLB slot already integrated onto it would accept an IBM VLB Riser -- After a bit more digging, of course, it seems like it'd probably not work unless the board had the BIOS setup for it, and there's also the form-factor to consider. It'd be nice to find a VLB-capable MoBo that could fit into a horizontal desktop ATX case that lines up with the back panel properly, like the case I already own. It'd be far cheaper and less wasteful, for sure.
I've seen a few Valuepoint PCs and MoBo's floating around on eBay - None of which are particularly faster than the 433DX 6384 I have in this computer, even though one or two of them -DO- have the VLB-slot that I'm looking into. This leads me back to my initial thought of "just begin anew" with a different 486 build. I dunno, this is probably the part where I should just take the advice of people with more experience than me.
I have a WinXP machine that is staring me in the face, right now, that just needs a good Case and PSU.
Reply 18 of 22, by JustJulião
Orzene wrote on 2025-03-22, 03:06:
Current main 3 PCs for different eras of classic gaming/programs -- https://i.imgur.com/jyeF2Oh.png […]
Win95 PC
Memory: 256MB Ram
Win98 PC
Notes:
Your wallpaper is so cool! What is it?
Reply 19 of 22, by Orzene
I have some Blender experience, and I wanted something that used Pre-PBR shaders / Gouraud shading. I installed Ver. 2.49b and made a simple 3D scene.
I then used Jasc Paintshop Pro ver. 6.01 to reduce the color depth with proper dithering. The nice thing about it is that it installs to Win10/11 with only a few errors, is easy to use and not quite as annoying as GIMP, plus it does proper classic dithering, and it exports .BMP files that even Win3.11 can recognize without needing to select correct the Indexed color palette.
Lemme see if I can upload these somewhere for people to download and use. I'd like to create more of these that feel like a traditional 3D renders from older software.
