First post, by Overfloater
Hello, I came here to ask for some advice. So I have an Abit BH6 motherboard, revision 1.1 which I use in my main retro rig. I previously used in it an 800Mhz Pentium 3 Coppermine with an FSB of 133, which was okay, but my dream was always to upgrade to a Tualatin 1.4ghz, but I never came across any of those older adapters that fit the bill for a reasonable price. Then I came across this product on eBay, and I purchased it. I've installed the board as per the instructions on this forum, and at first the PC booted with the new CPU without issues, but of course it was not running at full speed until I tried setting it up.
However immediately I realized the PC would not even boot with the FSB set to 133Mhz. So after lowering it to 126Mhz, the system would boot fine, but then at later bootups I noticed instabilities, like programs randomly crashing when I tried to launch them, including explorer.exe in Win2k. Raising the CPU voltage in the CPU soft menu from 1.45 to 1.6 volts seems to have finally brought the system to general stability though. I already asked the seller on eBay, but I figured I'd give it a shot and ask here as well if anyone has had any experiences like this with this adapter board solution, and using it with an Abit BH6 motherboard. Just for extra info, I have updated the board to the latest BIOS available, and I am using an Abit Slotket 3(or !!! as it's styled on the PCB), which is supposedly a supported Slotket for this setup. Any ideas, feedback, etc are welcome. Thanks.
