First post, by DUZ
Hello. I have been using dgVoodoo for years with Delta Force 1 and 2, but this time I would like to know if it is possible to achieve some improvements using it with Black Hawk Down as well.
At the moment, I notice that dfbhd.exe loses focus in Windows 11 after the first Alt+Tab, and in some cases, it even starts without focus on certain PCs.
I have been documenting these issues with notes and videos in a compiled report:
🔗 https://docs.google.com/document/d/1vis23hAb7 … dit?usp=sharing
So far, the only noticeable change in this behavior came from using the Swap Chain Override addon for ReShade.
Dege, do you know if there are any improvements we can achieve with dgVoodoo2 in this case?
Reply 1 of 1, by Dege
Thx for the deailed description. I don't have this game so I cannot test it now.
But anyway, I don't think there are 2 windows. There is only 1 window which is initially sized (and painted) to the resolution of the rendering (e.g. 640x480) and it's resized to the physical resolution of the desktop when dgVoodoo switches to fullscreen mode.
If scaling is 'unspecified' then the 2 resolutions are the same, but when you use for example "stretched, keep aspect ratio" then the desktop resolution is... your current desktop resolution.
The mouse is captured in the top-left corner of the rendering window, to the 640x480 sized area because that's what the game expects.
