First post, by keenmaster486
- l33t
Just an anecdotal experience.
Had a WD90C00 card in my 286-12. Was getting benchmark speeds of ~1800 char/sec in Landmark, ~430us in Topbench. Noticeable slowdowns in Commander Keen when drawing lots of animated tiles, sprites, etc.
Replaced it with a WD90C30. Now Landmark says ~2800 char/sec (noticeably zippier character fills on startup), and Topbench says ~330us. Keen noticeably much faster, difficult to get enough changing stuff on screen to slow it down.
I have always heard that a 286 will bottleneck a very fast ISA video card. WD90C30 is on the top tier, fastest ISA VGA cards you can get, in the same league as ET4000. WD90C00 is among the slowest. So that gives you a little idea of what a 286 can do.
My bus speed is 6 MHz btw. The only two options in the BIOS are to match the CPU clock or cut it in half, and the system did not run stable at 12 MHz bus, even with every wait state under the sun.
World's foremost 486 enjoyer.
