First post, by Matt The Cat
Hey there, I am trying to get the best compatible CPU for this motherboard. It is a Biostar M6TBA Ver. 1.4 with the i440BX chipset and the latest BIOS update: TBA0602B from June 2nd, 2000.
Currently it is running a Pentium III 450MHz. I don't know too much about the different architecture, but from what I found out, this is a slot 1 CPU.
There is no manual available online or much specific detail on the 1.4 version, but there are a few forum posts. Although there is several pieces of documentation for the 1.3 version.
Anyway, from reading up, I found that the CPU socket type should be Slot 1, in theory. Assuming that wasn't changed from board version 1.3.
For example, board version 1.3 documentation specifies max RAM size at 384MB, but I have maxed out my RAM at 786MB.
Additionally, I looked into Slot 1 to Socket 370 converters.
What I would really like is a CPU supporting SSE2, but I am pretty sure that is impossible with this mother board and that no socket converters exist that would allow a Pentium 4 or higher.
My current specs are:
Biostar M6TBA Ver 1.4
2 IDE hard drives (One 8GB running extended kernel Win2K, and One 60GB running Win7. But I have to manually swap connections and power)
i740 AGP GPU (unused but left in because the system wont display/work properly with it taken out)
PNY NVIDIA GeForce 8400 GS
3 SDR UDIMM sticks (maxed out at 786MB usable RAM)
Pentium III 450 MHz (Katmai? But this is what I want to replace)
Celeron and Pentium series CPUs seem to be the prime target for potential.
Overall, if you could help me find what the fastest natively supported slot 1(?) CPU is, that would be great. And if there are any additional steps like flipping switches on the board, because I am a real newb.
Additionally, if you could help me find what slot 1 to Socket 370 converter I would need for the best results, and what fastest CPU I could use with it is, that would be awesome.
Lastly, if any of you know of a way I could get an SSE2 supporting CPU to work (maybe a slot 1 or socket 370 CPU if that exists...)
To reiterate: I want to get the max speed CPU (without overclocking) to the best natively supported and/or what slot 1 to Socket 370 converter I need (and what is the fastest CPU I can use with it).
