First post, by youxiaojie
as we know 8k fresh chips use A12 however simm 72 simm 30 only A0-A11. if direct use, A12 tied to ground,is it ok alough I lost a half of size? if we create a address convert circuit, what is the logic? thanks.or is there exist ic for it?
Reply 1 of 1, by rmay635703
Older motherboards had problems with new memory refresh rates.
So If you can get the address it may have stability issues.
