Wake on lan doesn't work
First post, by briefsense
Hello everyone.
I have an old PC with a luckytech p6vbx2 motherboard, which mounts a 3com 3c905c-txm PCI ethernet card. The PC runs XP professional, and in addition to the good functioning of everything, except the internet, but I do not need it for that, I would like, as per the title, to make the wake on lan working.
The relative function is active in the bios, but reading the specifications of the chipset that the motherboard mounts, a VIA, I noted that the PCI compliance version is 2.1, which requires, for the WOL to work, a three-pole cable, to be connected between the motherboard and the ethernet card, as also written in the ethernet card manual, available online. With version 2.2 there is no longer any need for that cable.
After seeing that both the motherboard and the ethernet board have the connector for the WOL cable, I recover one, connected it and i noticed that indeed, with the PC completely turned off or in suspension, the LAN connection activation LED is turned on, both on the ethernet card and in the switch. So I tried to perform the WOL again, in both modes, mentioned above, but nothing happened.
I then updated the ethernet card drivers on XP, in which the most recent ones appear to be from 2002, there are a few more features in the "advanced" tab of the device listed in Device Manager, but nothing, the Wake on lan does not work.
From cmd then, I give the command "powercfg /a", it shows me that the PC supports standby and suspension in S1 mode. in suspension it goes, only from cmd, enabling the "hibernate" parameter, always in powercfg, while in standby, from the start menu, it seems to enter, showing the screen of switching to standby mode, but then shortly after, the monitor turns on again and returns to the desktop, I did not understand why.
However, I have not yet found a way to make wake on lan work on this PC. What other thing can I do?
Thanks to anyone who will help me.
Reply 1 of 16, by douglar
I gotta ask: 1) do you have the latest motherboard BIOS? 2) How are you sending the magic packet? 3) Do you have an actual use case or is this a "just because it is there" scenario?
Reply 2 of 16, by Errius
I had a very similar setup many years ago (440BX and 3c905 with cable to mobo) and could never get it to work reliably.
You could power it on remotely once, but after it shut down, it couldn't be woken a second time. You had to manually press the power button. I'm not sure what I was doing wrong. (OS was Windows 2000 Professional IIRC).
(I made use of this once, while overseas on holiday. I was able to power on the computer and retrieve files from FTP, but once I remotely shut it down, it stayed off until I returned.)
Is this too much voodoo?
Reply 3 of 16, by ElectroSoldier
On the older boards I could never get WOL to work consistently or reliably either.
Only time it worked well was on servers with a dedicated RJ-45 port for remote management.
Reply 4 of 16, by briefsense
douglar wrote on 2025-04-10, 18:22:
1) yes. I upgraded it using the .bin file downloaded from "the retro web" website.
2) I used 2 apps for WOL on Android (I don't know if I can write here the app URLs) and other three programs for windows, one from "nirsoft" website, one from "Aquilatech" website and another from "depicus" website. No one had turned on the PC, but I saw that the LEDs, both on Ethernet card and the switch has always blinked when I started the WOL command, from all those apps.
3) I use it with USB/IP, as a client, with puppy Linux as a server. Very reliable.
In addiction, I used in substitution of the 3com card, another card with the RTL 8139 chip, even with the WOL connector. same result as the 3com card, blinking led on WOL command, but not turning on the PC.
Reply 5 of 16, by megatron-uk
My experience, even working in a 'enterprise' environment, is that WOL was always hit and miss.
I've never had a setup where it worked consistently. The combination of hardware (and different hardware driver releases - e.g. the Intel Proset NIC drivers) bios settings and OS power save settings just resulted in too many variables to make it work reliably.
We had better luck with later machines setting bios scheduled power-on times (ready for students/researchers to turn up for the day). WOL not so much 🙁
https://www.target-earth.net
Reply 6 of 16, by douglar
megatron-uk wrote on 2025-04-11, 06:48:
I played with this in 1998/99 when I was doing some large Windows NT upgrades.
WOL worked on the prebuilt Dell & Compaq systems. I suppose that's not too surprising.
I tried recreating it at home with DIY components but didn't have any luck.
Pretty sure I was using this board: https://theretroweb.com/motherboards/s/asus-p2v
Here is a the network card I used ( The one that has the WOL cable attached. Lol!) https://theretroweb.com/expansioncards/s/3com … l-pci-3c905b-tx
I was using Win98. I see comments about "Disable Fast Shutdown" when using WOL with Win98. Might be something to check.
I had VIA two systems that the time. The Apollo Pro + and a K62 MVP3 system. That's when new versions of the Via 4-1 driver were rolling out from month to month. It's not so bad now that the drivers are stable, but it was frustrating to get caught in the churn back in the day. I can't recall buying Via boards for the next 20 years after that experience.
I was also trying to overclock a Celeron 300a, so I was probably asking for trouble.
p.s. Nope, on review, I did buy one of these a couple years later-- https://theretroweb.com/motherboards/s/asus-a7v133 I try to forget about the Thunderbird Athlons sometimes
Reply 7 of 16, by Errius
I was recently gifted a NOS HP Compaq Presario tower from 2009. It's junk, but I thought it would make a decent headless server. Stick it in a cupboard and use WOL and network to access it.
It doesn't have WOL. WTF? Why would you put a NIC on a motherboard but not allow WOL?
*shakes head*
Reply 8 of 16, by douglar
Errius wrote on 2025-04-11, 13:21:
*shakes head*
WOL was an enterprise focused feature. Deskpro & ProLiant? Yes. Presario? Not so much.
Reply 9 of 16, by briefsense
douglar wrote on 2025-04-11, 12:53:
So, I can't have any luck with custom PCs? Because I tried even with motherboards, not from prebuilt PCs, which have the integrated network card, and the WOL it works flawlessly.
Reply 10 of 16, by douglar
briefsense wrote on 2025-04-11, 13:50:
I'm just saying that back in the day when I was younger and smarter and did this stuff on a daily basis, I wasn't able to get a 3com 3C905 card to WOL with an apollo pro motherboard.
Are you running windows 98? Did you disable fast startup?
Reply 11 of 16, by briefsense
douglar wrote on 2025-04-11, 14:15:
I running windows xp professional.
But yesterday, I tried to use an HDD with windows 98, which was used on there, with same card. But same results, unfortunately.
What do you mean with fast startup?
Reply 13 of 16, by ElectroSoldier
I was thinking about this today.
I have a vague memory that it matters what PCI slot you plug the PCI NIC into.
Its something to do with IRQs. Something to do with the AGP slot too but its been so long I cant remember.
Reply 14 of 16, by briefsense
douglar wrote on 2025-04-11, 15:13:
Thanks for the guide.
I followed that steps, even if I use XP as I mentioned in the first post, and not 10 or 11, so it doesn't exist a function regarding the fast startup in powercfg.cpl, so I have unchecked the box regarding allowing the PC to turn off the hardware to save power, in device manager, and by unchecking this, it was automatically unavailable the next checkbox regarding allowing the hardware to wake the PC, that firstly it was checked, now it isn't anymore, until I recheck the first checkbox.
Reply 15 of 16, by briefsense
ElectroSoldier wrote on 2025-04-11, 17:30:
Now that you made me thinking, I had issues with this PC, in the past, which the network card seems to working only on the first PCI slot, like now. Else it wasn't revealed by the OS. I use however a video card with AGP.
Reply 16 of 16, by mdog69
If I had a system which had a NIC that recognised a WOL packet and an external WOL connector I'd use a small 8pin MCU (e.g. PIC12C509 or whatever replaced it) and have it turn the WOL signal into something that fed the motherboard power switch.
Having said that, I've always treated working WOL as a bonus.
