First post, by TheMLGladiator
- Member
I recently acquired a X1900 XTX used as-is. When I brought it home to test it, I found that the card isn't 100% functioning correctly. In text modes there is obvious corruption and only one of the DVI ports seems to work. I tried reflashing the bios with one from TechPowerUp (this one: https://www.techpowerup.com/vgabios/712/ati-x … amsung11-051221) and that didn't make a difference. The person I got the card from originally bought the card the day it launched, so it could have been a slightly older bios revision than what is online. What tools would I need to attempt a repair on this thing?
