First post, by GloriousCow
The best pel panning test for EGA is clearly Fantasy Land, but I'm wondering if anyone's aware of a text-mode pel panning demo for VGA.
I'd like to test my VGA emulation. Commander Keen works, but the VGA extends the pel panning by bytes as well as pixel, and there's a bit of a difference in how text mode pel panning works in text mode now that we have 9 columns.
If there's nothing out there I could hack up my own demo I suppose.
MartyPC: A cycle-accurate IBM PC/XT emulator | web version: https://martypc.net | https://github.com/dbalsom/martypc
Reply 1 of 14, by superfury
GloriousCow wrote on 2025-04-21, 21:22:
There's Tsengs' VDIAG, although maybe only for Tseng cards?
Then there's VGATEST. (https://github.com/barotto/VGATEST)
There's also tweak16b.
There's WHATVGA for easy coverage.
CheckIt Diagnostics (MS-DOS) tests some stuff too.
There's 'pgame' too (with source code), but don't remember where I found it.
Edit: Found it: https://pcem-emulator.co.uk/phpBB3/viewtopic.php?t=3089
There's https://forum.vcfed.org/index.php?threads/ega … nlines.1246033/ too, but that's graphics mode.
Also interesting:
https://hackaday.io/project/6150-beckman-du-6 … -a-new-vga-mode
The myth of the vertical retrace interrupt on EGA/VGA
UniPCemu Git repository
Reply 3 of 14, by digistorm
Are you familiar with these demoscene demos? Yo! and Starport both use the textmode way beyond they were ever meant to, including scrolling.
Reply 4 of 14, by lolo799
digistorm wrote on 2025-04-25, 07:48:
Talking text demos, there's the whole tmdc entries too https://www.pouet.net/search.php?what=Tmdc&type=prod
Reply 5 of 14, by GloriousCow
Thanks, those are perfect.
Here's Yo! in MartyPC.
https://youtu.be/f2B63J8h7eQ
The scrolling effect on the top is very clever - they are animating a shaded box texture through the VGA's font glyph definitions, but also scrolling the top with the pel-pan register, which moves the attributes (and thus the colored regions) at a different apparent rate.
The part beneath the scroller has pel-panning disabled because it is a split screen, and pel-panning is set to disabled in the split screen.
Reply 6 of 14, by GloriousCow
Funny enough - Starport isn't text mode at all. It's 640x350 16 color mode. It's just designed to *look* like text mode.
Reply 7 of 14, by GloriousCow
lolo799 wrote on 2025-04-25, 12:56:
Tried a few of these, most of them are protected mode or windows console apps. Still cool though, just can't emulate them yet 😀
Reply 8 of 14, by Soles
I haven't come across a dedicated text-mode pel panning demo for VGA either, but you could try tweaking some old DOS demos or games that use text mode with VGA graphics. A lot of the early text mode stuff had some quirks with panning, especially with the added columns. If you're up for it, hacking together a custom demo could be a fun way to explore it further!
Reply 9 of 14, by GloriousCow
Soles wrote on 2025-05-02, 18:43:
Yeah, that's the plan. I picked up an original IBM VGA (PS/2 Display Adapter) to do some tests with.
Reply 10 of 14, by VileR
I think Tiny-Demo should fit the bill, all text mode and plenty of scrolling abuse.
Reply 11 of 14, by vogxenova
@GloriusCow Nice.. That original IBM VGA should give you a pretty authentic baseline to work from. Definitely curious how the pel panning behaves on that, some of those quirks only show up on true vintage hardware.
Reply 12 of 14, by wbahnassi
Adlib Tracker 2 is "seemingly" text-mode VGA and allows smooth vertical scrolling with the mouse. I always wondered what cool trickery was that.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 13 of 14, by GloriousCow
VileR wrote on 2025-05-04, 03:17:
Oh this looks sweet, thanks.
wbahnassi wrote on 2025-05-04, 13:01:
Smooth vertical scrolling in text mode is pretty easy on the VGA, you can specify a starting glyph row, so just update that from 0-14 then update the start address to the next row and repeat.
Reply 14 of 14, by superfury
GloriousCow wrote on 2025-05-06, 15:38:
Oh this looks sweet, thanks. […]
Don't you mean 0-15? Since the character height is 16 (most of the time). Although it depends on what font you're using (anything from 1 to 32 lines per character row).
