First post, by Jackhead
Jackhead
Online
- Oldbie
So i have a pci soundboard that i want to use.
For this i installed the driver and device manager take it and say anything is working fine.
Soon as i start software using the device i got a message that device id not found.
So i checked my IRQ settings and found that the card has no IRQ! I think its because that device id.
Normally that would be fixed by installing the driver. Is there a way to maybe registry to put in the device id manually??
I also tryed a different PCI slot, any time same problem
regards
Chris
