Asus TUV4X and Pentium iii SL6BY 1.4GHz (SOLVED)
First post, by Kittyboy
The attachment IMG_2025-04-24-175408.png is no longer available
I purchased #2 each NOS TUV4X boards and #2 each SL6BT CPUs (see images), and of these boards and CPUs, I have tried to power both sets, and have failed!
I have been unable to get power on, no devices, no board LED, no PSU fan, all is completely dead so far? I am hoping for suggestions? I have the board manual and verified proper configuration of jumpers and power on button (tested). The ATX PSU w/ 20 pin power tests good, swapped power cables, removed drives one-by-one, swapped video cards, swapped one installed stick of 512MB SSR UDIMM Non-EXC memory in bank one and moved to other memory bank locations, new CR battery, checked all connections, still NO POWER. I know the ATX PSU and power supply and cable are good, all molex cables (tested). The board/CPU combos are not sending needed power-on info to the PSU, so it is not providing power to the system. What could it be? I have tried both board/CPU combos, same outcome. I only have a multimeter. Please help!
Pentium III 1.4GHz-S (SL6BY), Asus TUV4X, Plextor 760A, ATI 9800 Pro, MS-DOS 6.22/Win98se dual boot
Reply 1 of 137, by Horun
Have you tried ANY other socket 370 cpu ? Your board has BIOS 1005, you need bios 1006 to use that cpu iirc. Is the battery new ?
Reply 2 of 137, by Kittyboy
Horun wrote on 2025-04-25, 01:22:
I have no other CPUs currently and do not know how to update the bios without getting the system powered on first? What is the acronym IRCC? Battery is tested new.
Reply 3 of 137, by pete8475
Kittyboy wrote on 2025-04-25, 01:28:
iirc = if i recall correctly
Reply 4 of 137, by Imperious
If the bios version is the problem, You will need to get a coppermine cpu, boot off that, then update the bios.
Alternatively You could get an eeprom burner and update it that way.
There's a chance Your power supply could cause issues with only 20A on the +5v rail, and that will depend on what video card You use.
Reply 5 of 137, by Kittyboy
Imperious wrote on 2025-04-25, 01:59:
Good call! I was driving and thinking the same thing just now, if in fact that's what needs to be done, it would be the easiest way forward. I read the manual, it appears 1.0GHz is the highest GHz if not running the latest BIOS update. I assumed running higher CPU that the board would just click it down. So is it possible that this could cause ZERO power, not even the board LED?
Reply 6 of 137, by flupke11
Welcome to the hobby! As said, you'll need an older Pentium III to test the boards in their current Bios version. A Coppermine can be had fairly cheap, especially the lower models or the Celeron version (733, 866 etc).
It can be a pickle troubleshooting a mainboard without spare bits. You'll also need to make sure the ram works fine, as this might prevent a system boot as well.
Reply 7 of 137, by shevalier
Definitely, it's not bios/cpu problem
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 8 of 137, by Kittyboy
flupke11 wrote on 2025-04-25, 06:02:
Getting rid off all my "spare bits" has come back to haunt me 45 years later... Today I plan to root-out a CPU somewhere? I realized there would be some hunting around once I decided to go back down this road, all part of the fun. plus it has jogged some memories.
Reply 9 of 137, by Kittyboy
shevalier wrote on 2025-04-25, 06:58:
I hope you are wrong! 😀
Reply 10 of 137, by Kittyboy
In the case it is determined to be the board, what are your thoughts on re-capping? What updated type and brand of caps would you suggest?
Reply 11 of 137, by shevalier
Kittyboy wrote on 2025-04-25, 13:07:
These motherboards are very primitive.
There is nothing really to break.
I would first change the PSU and try to run it without the CPU and memory.
It should turn on.
+5V STB is used on them either directly or through a primitive regulator.
There must be some voltage on the MIO chip in standby mode, in addition to the battery.
MIO is responsible for turning on the ATX PSU, if it is even slightly alive, the motherboard fans should twitch at least slightly.
Kittyboy wrote on 2025-04-25, 13:14:
Which are free 😀
For example, from old-type Asus AM2+/AM3 motherboards with a diameter of 8 mm. For yellow PСB, I prefer red capacitors.
In fact, any cheap polymer capacitors - Lelon, Capxon PS, Samwha FB, ULR.
There are no hard currents at the 370 socket, any type of cheap General use polymer capacitor will serve as a direct replacement for the ultra-branded electrolytic of those years.
Reply 12 of 137, by myne
No power at all?
Got a multimeter?
Personally, I'd give it a thorough wash - eg dishwasher with no soap.
You'd be surprised how many things come to life again after a good clean.
I built:
Reply 13 of 137, by Kittyboy
shevalier wrote on 2025-04-25, 14:46:
These motherboards are very primitive. There is nothing really to break. I would first change the PSU and try to run it without […]
It should turn on.
Which are free 😀
I'll remove the CPU and memory and see what happens. The PSU is a new MSI (tested).
Reply 14 of 137, by shevalier
Kittyboy wrote on 2025-04-25, 18:43:
I looked at the photo of your board.
Its MIO functionality is in the southbridge.
VIA integrated this functionality, although few manufacturer used it. Keyboard/mouse/floppy/ATX_power_on/ATX_power_good was usually implemented on a separate Winbond/ITE chip.
But the VIA south bridge has a bad joke that if not installed additional parts (transistor or logic ic) on the power button, but connect directly from the pins.
Then the motherboard cannot be turned on with an uninsulated metal object - tweezers, a paper clip, a screw, etc.
Only an insulated one, like a screwdriver with a plastic handle.
Apparently, interference from the AC powerline is affecting.
I almost threw away a fully functional Socket 7 motherboard.
Reply 15 of 137, by Kittyboy
It should turn on.
Which are free 😀
I finally figured out my power issue! The modular power cable I was using with the PSU was not from the same vendor, apparently wired differently or just wrong? After getting a proper cable I got power to the board. The modular PSU setup combines two plugs, 10pin and 18pin, to a 20+4 ATX connector. Wow, what a week!!! The fun didn't stop there, after my tears of joy, still had a black screen, long beep, long beep, long beep (Award BOIS). Thought bad CPU or motherboard? I then re-set the board jumper from "jumper mode" with switch 3 ON to "jumper free mode" all switches off. Removed the battery, shorted the BIOS again, got one long beep and three short beeps. Shorted BIOS again, one long beep and two short beeps. Swapped graphic cards, shorted BIOS one more time, BIOS setup screen!!!! Tears of joy (see images). Apparently the TUV4X board setup is best in "jumper free mode" all switches off. I originally planned jumper free mode but was concerned, the board was sent with documentation showing up to 1GHz REV: 1005 BIOS, afraid it may cause potential issues. As it turns out REV: 1005 BIOS allows for manual settings up to the full 1.4GHz potential for P3-S (SLB6Y) CPU. I want to add, based on troubleshooting observation, with proper PSU power, the board LED will illuminate power ON with/without CPU installed, with/without memory installed. Also, no errors with only one bank of memory install, I am currently running 4x 512mb udimm non-ECC. I updated the BIOS to latest REV: 1006 using a:\aflash.exe with bootable floppy. Fortunately I have another P3 computer with USB. Downloaded the REV on USB, then transferred it to floppy for TUV4X. Good old days return in 2025! Now my latest dilemma, researching what CD-ROM drives are supported with Win98se install CD for Oak Technology ATAPI CD-ROM device driver? Mine are all too new as it turns out. I'm getting old based on optical drive evolution throughout the years. Anyone know a good list, small number were listed on the Windows CD under drivers. I think Plextor was a good brand, SONY... What is the VOGONS consensus for period Win89se optical drives for loading Windows98se?
Reply 16 of 137, by smtkr
Which CD-ROM drive are you trying to use? CD-ROM compatibility is not something I've thought about in the windows era.
Reply 17 of 137, by Horun
Good Work !
Reply 18 of 137, by maxtherabbit
Any IDE (ATAPI) CDROM will work the same as any other
Reply 19 of 137, by Kittyboy
Horun wrote on 2025-04-26, 21:35:
Good Work !
Thank you, it's been a fun journey so far. Always nice when you don't cook something foolishly. PS: I have had my share of cooking a few things in the past! haha
