First post, by butjer1010
Hi,
i don't know how, but i managed to buy Alaris Cougar motherboard, and it works fantastic. CPU works on 100MHz (fastest 386 on earth!!!), i have installed DOS 6.22 and Windows 3.1, but i have problem with Serial Port connectors! Mouse won't work in any JP 27 or JP28 via "good known cable". When i insert IDE controller with serial port on it, same mouse with same cable work normally (COM1 IRQ4, same setting are in BIOS (MR) when ide controller isn't inserted)?!? Could have both serial port connectors been faulty, or is there any setting in BIOS i can change to make mouse to work?
Thanks in advance!
