First post, by youxiaojie
what is the difference of 486sx dx dx2 de2 sl and wb wt?does normal board support 486de2?
and difference between 387sx and 387dx
what is the difference between 386sx and 386sl 386dx 386ex?
what is the difference from Cyrix 486 80 and v80? v80 has 4v 3.45v 3.3v version,what is the difference? is it because of procedure?0.8 0.6um?
Reply 1 of 4, by Horun
Basics: 486SX no mathco, DX has mathco, DX2 runs 2x internally, SL is Low power version, WB and WT are cache schemes.....
the 486 DE2 chips are AMD's 3.3v DX2's, if the board supports 3.3v cpu's you can use one, set same as a AMD DX2 but 3.3v instead of 5v.
387sx is mathco for 386sx, 387dx is mathco for 386dx. someone else can go thru the other 386's 🤣
Reply 2 of 4, by sp3hybrid
The 386dx has a 32 bit data bus while 386sx has a 16 bit data bus which means the sx needs twice as many memory fetches to get the same amount of data from memory which reduces performance significantly. This is similar to the 8086 and 8088 which differ by the width of the data bus but are otherwise identical. I belive the 386sx allowed board manufactures to use 286 chipsets which reduced cost significantly
Reply 3 of 4, by bertrammatrix
Define "normal board"
All 486 boards support 5 volt cpu's (so, you could call this "normal"), the ones made halfway through the era usually support 3.3-3.5 ish. In which case no, you couldn't run a DE2 in every motherboard.
Reply 4 of 4, by youxiaojie
