First post, by Beagles
Hi, was recommended this site from another forum. I have an DOS program called EPROM.EXE from Dallas Semiconductors (programmed 1994). This application has been running in a 16-bit DOS environment apparantly, as I get the message "Built for 16-bit DOS subsystem" when I try to run it. This when I tried to communicate through the COM-port in WIN XP. Any one that think that I could run this old DOS program in an 32-bit DOS enviroment, using DOSBox?? And how to start an .exe file in DOSBox??
I would very much appreciate any help in this matter!
Kind regards B
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
try reading the documentation that comes with DOSBox.
and yes DOSBox should run stuff from 94 just fine.
Water flows down the stream
Reply 2 of 4, by eL_PuSHeR
Rank Moderator
Moderator
You should take a look at this forum SECTION as well as doing what Qbix suggested.
If you are still stuck, keep asking.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 4, by Beagles
Hi again, did what you guy´s proposed, got DOSBox started. Also started my old program "half-way" using the really helpful intro text. Real good stuff!! 😀 .
But the only problem is that the program stopped after it had printed it´s name, saying that "COM1 DOES NOT EXIST" (see attachment). Is there a way to solve this? As the Dallas program apparantly uses the COM1 port. Can DOSBox use peripherals as COM ports?
Thankful for any help!
Kind regards Beagles
    COM1_problem.doc
    83.5 KiB
    105 downloads
Reply 4 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
hmm try a cvs build. preferable the one from aep emulation.
you can find more information about in the development forum (in one of the upmost topics)
