AMIBIOS tools questions.
First post, by lilkuz2005
Hey guys, I got an old slot 1 motherboard made by MicroStar its the MS-6111 using the 440LX chipset. I flashed the latest bios to the motherboard in hopes that it would support larger HDD's but it didn't. I saw a video by Necroware on youtube about modding the old AWARD bios's with a tool named bios patcher. My motherboard uses an AMIBIOS so I can't use that tool. I have been looking for something similar that supports AMI bios's. Does anyone know of any tools that can modify old AMI bios's? I took a look at the readme in the bios file I downloaded for the MS-611 and seen this in the Notes:
!!!!! IMPORTANT NOTES BEFORE PROGRAMMING !!!!!
Note1: This BIOS is a Plug 'n Play BIOS, and has to be used with SST or Winbond
Flash Memory. If this BIOS is programmed in EPROM or other brands of
Flash Memory (not SST nor Winbond), there will be a problem with Windows
95 RESTART function.
Note2: If your on-board BIOS is AMI BIOS and you want to program the Award BIOS
file into the on-board BIOS, you must use the "AMI" flash utility
(i.e.: AMIFL530.COM, AMIFL620.COM).
Note3: If your on-board BIOS is Award BIOS and you want to program the AMI BIOS
file into the on-board BIOS, you must use the "AWARD" flash utility
(i.e.: AWDFL52B.EXE, AWDFL534.EXE ).
Is it possible to flash an AWARD bios to this motherboard? I have never attempted anything like this in the past. Does anyone know anything about this? If I can flash an AWARD bios to this board then I can use those AWARD bios tools. Any help with this would be great.
asus p3b-f, intel pIII 1000/133/256 thermaltake golden orb, 2x crucial 256mb pc133, nvidia geforce 3, aureal vortex 2, IDE to SD adapter samsung 128gb evo
asus p3v4x, intel pIII 650/100/256, 256mb pc133, 3dfx voodoo 3 3ooo, awe64 value!, 80gb hdd
Reply 2 of 19, by jakethompson1
Check the AMIBCP thread. It's the 486-era ones that have no official tools out there; for you Pentium Pro/II era BIOS, there may well be an amibcp for it.
Reply 3 of 19, by Horun
How big of a hard drive are you trying to use ?
According to MSI TW archive for ms-6111: AMI BIOS Version Ver 1.4 Update date 1998-04-16
- Added support for over 8.5GB IDE hard disks. (and fixed some stuff).
https://web.archive.org/web/20011224153839/ht … p?model=MS-6111
Reply 4 of 19, by lilkuz2005
Horun wrote on 2025-04-29, 20:07:
How big of a hard drive are you trying to use ? According to MSI TW archive for ms-6111: AMI BIOS Version Ver 1.4 Update date 1 […]
I'm currently using a promise raid controller and I have a 120gb hdd installed. I would really like to modify the bios so I can use the raid controller in another machine. It's been a few years since I messed with this pc but I think I was able to install either a 10gb or 20gb hdd but anything bigger wouldn't work.
Reply 5 of 19, by lilkuz2005
byte_76 wrote on 2025-04-29, 19:08:
Maybe this will be of interest to you:
https://vswitchzero.com/ms6160/
yeah he was able to mod the ami bios but he was not able to add more than 37gb hdd limit. I wish he wrote more about the award bios he used on that board, I know he said he had problems with it but I wonder if it had support for larger drives? Also wonder if MSI ever made an award bios for my ms-6111, all i can find are ami.
Reply 6 of 19, by lilkuz2005
jakethompson1 wrote on 2025-04-29, 19:42:
I downloaded a couple versions but when i try to load the ROM it gives the incompatible ROM error. Maybe i need to find a version older than 2.25b ???
Reply 7 of 19, by cyclone3d
Best way is to get an EEPROM flashing tool and flash the BIOS you want to try onto another EEPROM of the same type.
Also need to make sure the EEPROM your board has, has enough capacity for the AWARD BIOS.
You will want a second EEPROM either way because you have a good chance of no-boot flashing a different boards BIOS.
If you really want to try it without a backup, you can probably use Uniflash.
Guessing there will also be a force flash option you would have to use.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 8 of 19, by Horun
There are some possible Award versions for i440LX + W977TF bare LX boards that are from 12/1999 or later (when greater than 32Gb hd support came out).
With a eeprom programmer one could try the Award from these: ABit AB-LX6, FIC VL-601 Rev 1.1, Gigabyte GA-686BLX, Gigabyte GA-686LX3, just to name a few....
Reply 9 of 19, by jakethompson1
Just to state the obvious, you've already considered disk overlay software and just don't want to use it?
Reply 10 of 19, by lilkuz2005
jakethompson1 wrote on 2025-04-30, 01:19:
Yeah, I would prefer to mod the bios to support the larger drives. I'm using a promise raid controller right now and that is adding a bit of time every time I reboot the machine. It would be really nice If the board just supported the larger drives.
Reply 11 of 19, by lilkuz2005
Horun wrote on 2025-04-30, 01:02:
If flashing a bios from a different vendor, would information about my motherboard still show up in post? I have an old tl866ii plus programmer that I can manually flash the bios with. I just never attempted flashing a bios from a different board before.
Reply 12 of 19, by lilkuz2005
I looked around for msi motherboards that also used the 440lx chipset, I found this one https://theretroweb.com/motherboards/s/msi-ms-6117-lx6#bios , it also had a patched bios that supported 128gb hdd's and it was an award bios. I removed the eeprom and flashed the bios manually with my programmer, testing the new bios I just got a black screen. I flashed the original AMI bios back manually with the programmer, and the system is booting again. I'm not sure if it's possible to use a bios from another motherboard.
Reply 13 of 19, by maxtherabbit
lilkuz2005 wrote on 2025-04-30, 10:44:
The POST string is hardcoded in the BIOS binary
Reply 14 of 19, by Roman555
lilkuz2005 wrote on 2025-04-29, 18:50:
Why to not patch AMI ? As I understood the BIOS Patcher is universal and it also supports AMI bioses.
Try to patch the older versions because it didin't find any 32GB problem in the latest one (see the spoiler).
But maybe it was fixed in the newer version of the BIOS Patcher:
https://www.vogonsdrivers.com/getfile.php?fil … 241&menustate=0
Spoiler
https://www.rom.by/comment/18105
microstar.ru/ssl/php/upload/bios_files/a6111v18.exe
BIOS Patcher ver. 6.00.alpha_10. |for Award/Phoenix & AMI bioses|
Attention! Advanced qualification is required!
Found 1Mbit AMI BIOS!
!! Module Manipulation Successful !!
4. 32Gb-problem : not found.
Tweak options addinng:
if you can`t see all messages - choose 80x50 mode or run with ">report.txt".
(c)2002-2004 apple_rom, www.ROM.by
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 15 of 19, by Horun
Quirk in early LBA 28bit implementation (pre 2000) is a max 33Gb limit, when it should work up to 127Gb iirc. Not sure if the bios patcher can detect diff between early buggy and good LBA 28bit.
Patching an older BIOS is a good idea !
MSI ms-6117 has no multiplier jumpers (bios set) where the ms-6111 has jumpers (switches) so no surprised that boards bios does not work....
Reply 16 of 19, by lilkuz2005
Roman555 wrote on 2025-04-30, 14:27:
Why to not patch AMI ? As I understood the BIOS Patcher is universal and it also supports AMI bioses. Try to patch the older ver […]
Spoiler
I thought bios patcher was just for award bios's. I had no idea. I ran the version you shared in your post against my bios v18 and got this output:
Spoiler
BIOS Patcher ver. 6.00.alpha_15. |for Award/Phoenix & AMI bioses|
Found 1Mbit AMI BIOS (core 0627) !
4. 32Gb-problem : -> fixed.
error!
0004>Too many open files
(c)2006 Angel07, www.cgi-scripts.info
Reply 17 of 19, by Horun
Ok I ran the patcher under Xp 32bit on the v1.7 and the v1.8 bios from TRW. Both times say fixed 32Gb problem and 65Gb problem.
Attached the fixed v1.8 rom file. If you try it be sure to rename A611MS18_fixed.ROM to A611MS18.ROM to keep the 8.3 file naming if you choose to use the AMIFL634.COM to flash.
Suggest you use your eeprom flasher to flash it.....
Spoiler
7. 65Gb-problem (1-st step) : -> fixed.
8. 65Gb-problem (2-nd step) : -> fixed.
Reply 18 of 19, by lilkuz2005
Horun wrote on 2025-04-30, 16:20:
Ok I ran the patcher under Xp 32bit on the v1.7 and the v1.8 bios from TRW. Both times say fixed 32Gb problem and 65Gb problem. […]
Spoiler
That worked, I flashed the bios with my programmer, removed the promise raid controller and connected the ide cable to the motherboard, in the bios auto detect drives wasn't working correctly, I had to manually set the cylinders heads and sectors but saving the settings and rebooting and its working. Thanks for all the help. I appreciate it.
Reply 19 of 19, by Horun
lilkuz2005 wrote on 2025-04-30, 16:56:
Great !!! Yes some times older bios have issues proper detecting the HD parms on large drives on "patched" bios. Be sure to write down some notes on what you have done, for future record 😀
Roman555 and douglar deserves the credit 😁
Yep ! Thanks, the newer version seemed to fix the 33Gb/64Gb limit so should be ok to 120Gb
