First post, by clownwolf
I bought two of these new old stock Slot A boards about 4 years ago, and stored them in a clean dry place so they are pristine. I have just gotten around to testing them today, as I was fully occupied just before they arrived years ago.
The issue is neither of these SD11 boards wont turn on. I even tried holding the power switch for >5 seconds, but both motherboard and PSU fans wont even spin. Wouldn't it be very unlikely that two new old stock boards would have the same exact power issue?
Just to be sure I tested the power supply and the power switch with some motherboards next to them in storage. The PSU and switch successfully turns on 3 Socket 478 motherboards I tested.
Am I just missing something obvious here, or am I just unlucky in getting 2 dead boards? As seen on the photo below, the silkscreen shows that the power switch should be placed on the pins 3rd from the left, and thats exactly where the switch was placed.
Photo of both boards
