First post, by Paar
- Member
Bought a pair of 6 pin ribbon cables to tinker with SB Link mode on some of my sound cards. Worked fine with Yamaha YMF724 card but I just cannot enable it on my Terratec ESS Solo 1. Every time I try to initialize the card in DOS is informs me that the card is in DDMA mode. Tried to HEX edit the ESSOLO.INI file to force SB Link but Wolf3D hangs when trying to play PCM sound and Doom just doesn't play anything.
Is there some kind of trick to enable the mode on the card? The pinout is a little weird but the continuity is there with the Solo chip. My board is Soyo SY-6BA+ III with Intel 440BX chipset.
