First post, by paradigital
I’ve decided that I have too much stuff, whatever doesn’t go into a build (including case), or offer a spare part to a build (so a spare video card for each build, spare RAM, spare CPU, etc) is getting sold off.
I happen to have the parts to build two Slot 1 systems currently, with either of the following boards.
Asus P3B-F.
Abit BE6-II.
The Asus has two ISA slots, the Abit has one.
The Abit has a RAID controller for ATA66.
Either way, the build will be going into a Cooler Master ATCS-201, the brown one. Will be running a P3 Tualatin 1.4 in a Powerleap IP3-t, and will be housing Voodoo II in SLI (not sure what primary GPU to add, should it be a 3D card in its own right, or a 2D card, I have a decent selection of both).
