Oops, meanwhile I've installed the card, and can't make a photo now - I will do it later if really necessary.
Anyway, all the jumpers are in the leftmost position - which, among other things, means EEPROM SETTING.
In the BIOS:
- Load setup defaults
- IRQ 5 = Legacy ISA
- IRQ 9 = Legacy ISA
- IRQ 10 = Legacy ISA
OS is Windows 98SE with BootGUI=0
Originally, nothing sound related in CONFIG.SYS and AUTOEXEC.BAT
a:
install
installation directory = C:\WAVRIDER
Do you wish to make changes on hardware and CD-ROM settings? - YES
HARDWARE CONFIGURATION -> DEFAULT SETTING
WARNING: This will restore the sound card to its default settings. All changes will be lost! - Continue
SB: 220H, IRQ 5, DMA 1
MWSS: Yes, 530H, Enabled
MPU401: Yes, 330H, IRQ 2
Do you want to restore the default settings? - Accept
Factory default settings are restored successfully!
RESET button
CONFIG.SYS - no changes
AUTOEXEC.BAT - the following got added:
SET GALAXY=A220 I5 D1 K10 P530 T6
SET BLASTER=A220 I5 D1 T4
SET SOUND=C:\WAVRIDER
The Ultimate DOOM Setup ver 1.9
Music - General MIDI - 330
Sound - Sound Blaster - 220 - IRQ 5 - DMA 1 - Number to mix 3
Save parameters and launch DOOM
...works fine with both music and SFX!
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
