Below you can see I can quite easily make SIV say Texas 486DX4, and the CPUID of 0481 matches the Intel DX4 of 0480 with a different stepping, but the $64,000 question is, "what does a Cyrix DX4 report?".
I don't have and can't find any documentation on what a Cyrix DX4 will report in the DIR + CCR registers so we need to get a dump from one. If you have one please generate similar to as below using SIV V5.81 Beta-07 or later and post it to this thread. Press the [_]CPUID check box to get the [CPUID CPU-0] dump, note the DIR + CCR register data should be the same on NT and 9x systems.
I am also wondering how many cycles an AAM takes on these DX4 CPUs, I just changed SIV to use 17 for the Texas DX4, the same as the Cyrix DX4 and with the revised number the speed should report as about 100 MHz.
Michal Necasek says: February 17, 2017 at 10:29 pm posted to https://www.os2museum.com/wp/whats-in-a-name/
I can’t find any documentation for the non-Cyrix-branded Cx486DX models. The documentation exists, just doesn’t appear to be available.
However, sources tell me that the Texas Instruments 486 DX2 and DX4 CPUs can be distinguished through the DIR0 register (contains 80h/81h rather than values in the 1xh range which Cyrix CPUs use). So far I see no hints that IBM- and ST-branded CPUs differ from Cyrix.
So I guess the Ti 486 DX2 will report 80h, if you have one or an IBM- or ST-branded CPU please will you post SIV dumps.
