First post, by MrWeedster
Recently i was lucky and got a load of these workstations in pristine condition.
Most of them are single PIII 1Ghz with 256MB and a Matrox G450.
One of them was a dual PIII 1Ghz which i've chosen as one of my retro pcs.
They're looking like fresh out of the shop minus all the dust that they've collected over the years, and also the PSU fan is a bit too loud for my taste so i gave it an overhaul.
First of all the PSU fan. It's a 92mm Nidec which is turning way too fast and thus too loud
The attachment IMG_1617.jpeg is no longer available
Let's replace it with a Noctua:
The attachment IMG_1618.jpeg is no longer available
Looking good
The attachment IMG_1619.jpeg is no longer available
Next up: Assembly
Reply 1 of 12, by MrWeedster
After cleaning the case and board drop in the mainboard
The attachment IMG_1620.jpeg is no longer available
The attachment IMG_1621.jpeg is no longer available
Cables
The attachment IMG_1622.jpeg is no longer available
CPUs and airflow guide
The attachment IMG_1623.jpeg is no longer available
Complete
The attachment IMG_1624.jpeg is no longer available
Running quiet and silent now. The CPU fan isn't too loud so i didn't replace it.
Specs:
Dual PIII Slot 1 1 Ghz
2x128MB and 2x512MB RAMBUS
Hitachi 147GB SCSI disk
Leadtek Winfast A350 FX5900XT
Floppy
Toshiba DVD-ROM
Q3 timedemo four (r_smp 1):
640x480: 115FPS
1024x768: 109FPS
Reply 2 of 12, by MrWeedster
And of course it's a AP550.
The attachment ap550.JPG is no longer available
Reply 3 of 12, by H3nrik V!
That's cool! Are they all same type of motherboard, as in, are they upgradable to dual CPU?
Reply 4 of 12, by MrWeedster
H3nrik V! wrote on 2025-05-14, 11:23:
Yes. For second CPU usage they need a VRM and of course a second CPU
Reply 5 of 12, by H3nrik V!
MrWeedster wrote on 2025-05-14, 11:31:
Awesome!
[Edit]: how many are "a load"? 🤣
Reply 6 of 12, by MrWeedster
A few 😀
Do you want one?
Reply 7 of 12, by momaka
Nice haul!
In regards to the loud PSU fan, let me guess - that PSU was OEM'd by Astec. 😀 For whatever reason, they always set the fan controller in their PSUs to be a bit on the "too loud" side. Most likely the other stations with other OEM PSUs don't have that problem (looking at the back of the leftmost station in this picture, that one uses an SPI/Sparkle/Fortron/FSP PSU.)
Hey, at least it's full of good Japanese caps. 😀
I also like how clean out yours has come out. It's pretty close to pristine, actually - not even light scratches or wear anywhere! WOW.
Reply 8 of 12, by chinny22
MrWeedster wrote on 2025-05-14, 17:42:
A few 😀
Do you want one?
Dual slot 1 motherboard with RD RAM, I know I do!!
VRM's and CPU's should be fairly easy to obtain to get these bad boys upgraded as god intended.
These had that cool design where you could rotate the drive bays 90 degrees depending if you wanted it in a desktop or tower setup.
Reply 9 of 12, by H3nrik V!
A few 😀
Do you want one?
Wouldn't we all .. 🤣
If it wasn't that I have a Dell precision Workstation with dual slot 1 and RD RAM (expected i840 chipset) I might have had room 😉
Reply 10 of 12, by momaka
H3nrik V! wrote on 2025-05-16, 21:33:
Nah. Even after all of these years in obsolescence, I still find RDRAM stuff too expensive for my taste. 🤣
I mean, I can practically build a complete retro system (or two) with what I'd pay for a stick or two of RDRAM.
That said, I do think RDRAM is cool nevertheless.
Reply 11 of 12, by H3nrik V!
momaka wrote on 2025-05-17, 20:17:
Nah. Even after all of these years in obsolescence, I still find RDRAM stuff too expensive for my taste. LOL I mean, I can pract […]
IMO, RDRAM could probably do some good in dual systems, especially with i840 chipset. Didn't make sense for a normal P!!! since SDRAM excelled in being synchronous to FSB where as RDRAM on an i820 and single cpu was a mess of wasted cycles, even skipped cycles, making the faster speed totalt useless at best. But with 2 cpus and dual channel RDRAM it could make sense ...
Reply 12 of 12, by Jackhead
I didnt know Slot1 also work with VRAMs? Nice build, i like the case alot! And Rambus on a P3 also very cool..
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - GUS ACE - MPU-401AT with YucatanFX
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
