First post, by Francois5942
Hello,
I have a Retro PC based on a MSI 6734 ver 1.0, Athlon XP 1800+. I have 3 partitions :
C: WINME
D: DATA
E: RECOVERY
The OS is Windows ME. When I plug a USB stick, Windows recognize it and it appears in explorer.exe, everything work fine. In explorer we have :
C: WINME (DOS primary)
D: DATA (DOS extended, first partition)
E: RECOVERY (DOS extended, second partition)
F: DVD ROM
G : USB MASS STORAGE
But if I reboot the computer with the usb stick plugged, I have a new hard disk in explorer :
C: WINME
D: local disk
E: DATA
F: RECOVERY
G: DVD ROM
H: USB MASS STORAGE
This behavior cause bug, all links to data on D: or E: don’t work anymore. If I eject the usb stick. The drive D: remains and if I try to shut down the computer, the floppy drive activate in looping and the computer never stop.
I reinstalled Win ME several times and tried different versions of the driver VIA 4in1. No change
I tried Windows 98 SE and same behavior. It s like When Windows start, it detect the USB stick has the first drive in the DOS extended partition.
I tried to Check in the BIOS if there is option for helping but no chance for the moment. I tried to enable or disable USB legacy, to desactivate boot on usb, to disable USB 2.0.
I googled but I didn t find anything.
If I put a PCI extension USB 2.0 card and plug my USB key on it and I reboot, this Time I don t have the behavior with a local disk drive, it works fine.
Is this an issue with my motherboard? What in the boot process could lead to a duplicate drive in explorer?
