First post, by Elixium
I have the newest 12/22/2003 BIOS installed but the AXDA2400DKV3C CPU is detected by the motherboard as an Athlon 1800+
I have a single stick of PC133 ram installed as confirmed by CPU-Z.
Is there no way to push CPUs on this motherboard past 1500mhz?
I've tried the onboard automatic overclocking feature but it won't go past 1650mhz and the CPU is rated for 2000mhz @ 133 fsb / 15x multiplier.
Reply 1 of 2, by Elixium
I've just noticed that there's FSB dip switch settings on the board itself mentioned in the manual... lets see how this goes.
Reply 2 of 2, by Elixium
BIOS & CPU-Z now detecting an athlon XP 2400+ running @ 2,000mhz after adjusting the SW1 dip switches, *SOLVED* indeed
