jakethompson1 wrote on 2025-05-16, 19:08:
I've wondered why Socket 5, technically, only supports 75, 90, 100, and 120 MHz processors. Per the datasheet (http://datasheets.chipdb.org/Intel/x86/Pentium/24199710.PDF p. 69):
Yes many socket 5 boards had very weak power regulators and would many times retroactively delist support for p166+. (Hard to imagine this was a real problem if you stuck to Intel CPUs)
A Socket 5 motherboard may or may not work correctly with a p120 because the definition of how the multiplier pin functions changed relatively late. In such a board setting 2x will still get you a 1.5x multiplier.
Some socket 5 boards will drive a regular p133 even though it’s not listed which was considered the first of the “next generation “ after the p75-120.
My view on the issue is that nothing above 100mhz existed when many socket 5 boards were manufactured and 120mhz was expected but forward looking so its lack of support isn’t a real issue, p133 just didn’t exist yet.
Back in the day the only reason to buy a real Intel Pentium overdrive was because you had an early socket 5 board that lacked multipliers, honestly can’t think of any other reason someone would use the Pentium 125 or Pentium 180 overdrives other than having an old board that was missing the needed jumpers.
