First post, by BetanoL
The game works fine... but i just can't use the mouse... It just doesn't work... What is wrong??
PS: What is the resolution that is lower than 640x480? I dont remember... 😁
DOS RLZ!
DOS RLZ!
well... anyone?
DOS RLZ!
320x200
320x240
400x300
480x300
512x384
640x400
And I have heard of others not quite as common. Can't recall them off hand.
About the mouse, I can offer only the generic suggestion of trying to use Ctrl-F10, if Dosbox hasn't already captured it. Or checking out the install program and the hardware configuration to see if the mouse is enabled under "Game Interface Options". The options/names on your version may vary of course.
I too have the same problem using the mouse as well as sound running MOO with DosBox. The mouse problem would be great to fix especially because I downloaded DosBox just for this game.
If someone could help out that would be great.
I am running ME with a logitech mouse through usb if that helps??
did you configure the game to use a mouse ?
as it's an option in install.exe.
if you select it then it works fine.
Water flows down the stream
i have just started running moo with dosbox and defend. it's running fine but just seems to be running slow. e.g. response to mouse clicks and screen transitions. is there a simple way to try and speed it up?
is there a simple way to get people to read the documentation of dosbox ?
ouch! Derek is that you? i have done some reading of the forums, so i am not 100% lazy maybe just 75%. i'll keep reading.
People are asking stuping question about speed very often... Even when there is almost everywhere written about it... They just cannot read or are lazy to do it.. You are not 75% lazy but 99%...
And behave to people who provide you something for free unless you are better than them (QBix is one of the two main developers of DOSBOX).
Mirek
Check out the DOSBox Guides section - there's even a guide titled "how to speed up DOSBox". There's also a sticky post in DOSBox General and DOSBox Games/Apps that says "READ DOSBOX GUIDES FORUM"
