First post, by crystal
I have installed Windows 3.11 inside Dosbox v0.74-3 to get some old games working, and I was trying to write some batch scripts to automate swapping CDs and launching games. I encountered an issue when I tried calling a common batch script where any further commands inside the calling script will be ignored. The CALL command is supposed to allow the calling script to continue executing, and it does when I run the command from the DOS prompt, but when I execute the script from Windows by creating a shortcut to it in Program Manager and opening it, it behaves exactly the same way as it does without the CALL command.
I found this thread from 2013 which I am pretty sure is discussing the same issue, though it's talking about Norton Commander and not Windows. There is a patch on that thread, so I guess I'm kinda curious as to why this hasn't been upstreamed if it fixes things in Windows.
Reply 1 of 3, by doshea
crystal wrote on 2025-05-17, 08:50:
That thread was actually discussing roughly the same version of DOSBox as you're using - in the last 12 years, it's just had a few hotfixes for critical issues, but not much else. There's probably a thread somewhere in one of the DOSBox-specific forums on this site explaining why there haven't been any significant updates for some time. You might find that one or more of the more actively maintained forks of DOSBox includes the fix. I'm afraid I don't use any of the forks so I can't recommend one, but if you look around some of the forums you might get some idea of which ones people prefer.
Reply 2 of 3, by jmarsh
Ripsaw committed that fix 10 years ago, just use any build that isn't ancient.
Reply 3 of 3, by crystal
doshea wrote on 2025-05-24, 08:01:
I see, I didn't realize the version I was using was so outdated since it was the latest released version from my distribution's repositories. I'll try again with one of those forks compiled from source. Thank you.
