First post, by fsinan
I've tried synchronous and asynchronous mode on the board with on board crystal at 80Mhz and seperate 50Mhz crystal for 25Mhz asynchronous mode.
System locks up at landmark at video test stage and nssi at fpu speed. SI works well but I dont know if it tests fpu. It reports the fpu as Intel 387 at 20Mhz.
No document available at the net. Only jumper settings. Without fpu there is no problem at all, flawless system. What could be the problem? Tried 2 different new intel fpus. There is no other brand at hand in PLCC-68 packaging.
System:1
Cyrix 5x86-120GP & X5-160ADZ
Lucky Star LS-486E
System:2
Intel DX4-WB & AMDDX4-120
PcChips M912 V1.7
System:3
AMD K6-2-475 & Cyrix 6x86MX PR-233
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 1 of 7, by Horun
I suggest you run the "Intel387sx Math CoProcessor Utilities" and see what it says. If you google that, you will find it....
also this manual may be of some help: https://archive.org/details/intel-387sx-users-guide
Reply 2 of 7, by fsinan
Horun wrote on 2025-05-17, 19:04:
Will try the software utility. Thanks.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 3 of 7, by PiotrUU
in asynchronous mode: In this case,
the ratio of the frequency of NUMCLK2 to the frequency of CPUCLK2 must lie within the range 10:16
to 14:10
I used a sx-33 system with a 25MHz FPU
I think you are trying to get your 387sx-25 to work too fast
the original 387sx has an old core - it doesn't work at 33 Mhz.
If you can, use a 387SL - it has a new core - they work at 33 Mhz.
I noticed that the parts marked 16-25 Mhz also have a new core as do the SL parts
Reply 4 of 7, by Horun
Good point ! at 25/40 (o.625) it is at the extreme low limit of 10/16 which theoretically should work, but due to age of stuff it just may be a bit flaky running that tight.
Reply 5 of 7, by PiotrUU
I think the fpu frequency can only be one degree different from the cpu. It's the same with the Motorola mc 68881/2 fpu
Reply 6 of 7, by fsinan
In theory it should work in asynchronous mode at 25Mhz, at the limit but. IN synchronous, it does not even boot every time. 40Mhz is simply not stable.
NSSI strangely reports at 20Mhz, I'm sure that crystal is 50Mhz for fpu. Maybe it is a little lower, that's why it is not working. Maybe I should try a 60Mhz crystal to make it work at 30Mhz if it can handle.
My fpu is old one I think.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 7 of 7, by MikeSG
Ulsi & Cyrix/Reveal 387sx FPUs work at 40Mhz... not sure if any others do. There is an Ulsi on Ebay at the moment for a good price...
A year or two ago I got 172.73 in Landmark on an ALI1217 board, Ti486sxl2-66 and a Cyrix/Reveal FPU at 33Mhz... performance is 90% the chipset
