First post, by maxtherabbit
Ordinarily for an AT or later system the system BIOS will only support two floppy drives. Obviously there are some exceptions like MR BIOS, and there are also installable device drivers (my favorite is WONDER34.SYS) which solve the problem when used along side DRIVER.SYS.
But there are also option ROMs which totally take over floppy control from the system BIOS, I have one already from Longshine which came on a 4 drive controller I have from them. It works well enough, but it has a major limitation- it doesn't work properly when shadowed.
So what are the other options out there? I've heard there is one from Sergey but I have no experience with it.
Reply 2 of 12, by maxtherabbit
The actual firmware is here:
https://github.com/skiselev/floppy_bios
And now I remember why I didn't try it before, it expects to be installed on an EEPROM to save its configuration back to itself. Although the docs do describe how to hard code the values yourself before programming
Reply 3 of 12, by DaveDDS
You'll have to confirm that your floppy controller hardware supports 4 drives correctly.
When they made the PC, IBM decided that changing drive jumpers was too complicated for the average
buyer, and they didn't want to stock two drives differing only in jumper settings ( A: and B: )
They also expected to run from floppy in many cases (the 5150 didn't have a hard drive), so they wanted to
not be running all drive motors all the time (the interface has only 1 "motor-on" signal)
So they came up with the wanky twisted cable between drive A: and drive B: which makes select A: appear at B: for physical
drive A: and brought motor-on for A: to a different signal.
This means the "standard" C: and D: selects are not in the right places on the IBM FDC board connector (and most mainboards
made since) and in many systems are simply not hooked up at all...
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 4 of 12, by maxtherabbit
DaveDDS wrote on 2025-05-17, 19:45:
You'll have to confirpcm that your floppy controller hardware supports 4 drives correctly.
No problem there, I'm currently using the WONDER34 installable device driver (as recommended by Chuck G) to operate all 4 drives in DOS, and they work a treat with IMD /4 too 😀
Reply 5 of 12, by maxtherabbit
So can anyone chime in with some hands on experience with Sergey's firmware?
Reply 6 of 12, by Disruptor
I'm also interested how I can access floppys from a secondary FDD controller like on an Adaptec 1522.
Reply 7 of 12, by maxtherabbit
Disruptor wrote on 2025-05-17, 21:37:
Sergey firmware purports to support drives on both primary and secondary FDC
Reply 8 of 12, by rmay635703
The quad floppy controller I had
1. Had its own bios
2. Had 2 separate cables
I did own a non-standard Innovion pgs3 graphics system and the 3.5” floppy in that had a massive number of jumpers for all sorts of different drive select / ID# crapola I have never seen in a pc.
The only time I’ve seen a floppy cable with 3 connectors was in a system with dual floppies but the tape drive was on the same cable, never understood how that worked.
Reply 9 of 12, by maxtherabbit
Yes every "IBM" style 4 floppy controller is going to have two separate cable attachments. Internal and/or external. One header will have drives 0/1 wired and the other will have drives 2/3 wired
Reply 10 of 12, by maxtherabbit
Well I broke down and setup an EEPROM to test out Sergey's floppy BIOS. So far it seems perfect. I'm not shadowing it and performance is good. It is able to handle drives on both primary and secondary FDC simultaneously and lets you define them in any logical order irrespective of the physical drive selects. Pretty cool
Reply 11 of 12, by maxtherabbit
OK I found one issue with it - floppy file operations no longer work in windows 3.11. This could be attributable to my using 32-bit disk access for the hard drive.
Windows works fine otherwise, and will even display the directory of any floppy drive, but it crashes when you try to copy a file from diskette to the hard drive.
Reply 12 of 12, by maxtherabbit
I was able to solve the windows 3.11 issue. All I had to do is define a 4th drive in the multi floppy BIOS and now it Just Works. The drive doesn't even have to be physically present.
