First post, by Elixium
I have the Yamaha S-YXG50 SoftSynth installed on Windows 98SE (real hardware) and its working to playback .mid files on the desktop.
In DUKE3D I have General Midi selected on 330h, when I hit test music there's no audio output and no error message.
In Windows I have the Yamaha S-YXG50 SoftSynth set as the default instrument.
I'm using a Creative SoundBlaster ViBRA 16C CT4180 ISA Sound Card, I have no drivers installed for it beyond what happens automatically when using the oerg866 Windows 98 Quick Install.
Reply 1 of 6, by Elixium
Forgot to add: The sound effects work in Duke3D but no music output.
Reply 2 of 6, by Babasha
VDMsound for Win98 (alpha version, very glitchy)
DOSbox for Win98 (midi ok but it emulates soundblaster over exists soundblaster?)
Need help? Begin with photo and model of your hardware 😉
Reply 3 of 6, by SScorpio
The Vortex 2 cards are the only thing I'm aware of that lets you select the Windows MIDI output device to use from a native DOS window.
Reply 4 of 6, by Elixium
Babasha wrote on 2025-05-20, 22:08:
Running on this athlon XP 2400+ Frame rate was awful even on 15,000 cycles on Dosbox 0.65 (newest for win98)
Still no midi music even though dosbox says the midi device is selected.
Guess I'll be dual booting Windows XP and checking out what DOS gaming is like in there, It seems like there won't be any issues making soft synths work in there.
Reply 5 of 6, by Elixium
Solved by upgrading to an Audigy 2 (PCI) following the guide on here " Guide: Installing Windows 9x and DOS drivers on Audigy cards (version 3.1)"
General Midi now works in Duke3D inside a regular ms-dos window (Windows 98SE)
It's not the Yamaha but its something & the Audigy allows for custom sound fonts.
Reply 6 of 6, by stanwebber
if all you need to do is redirect output in an msdos window to the windows midi mapper, the vdmsound win98 alpha works rock solid so long as you disable everything except mpu-401 emulation in the config file. you can even remap between mt-32 > gm & vice-versa.
