No power to motherboard
First post, by stealthjoe
Hi,
I am facing yet another setback. Have a socket 370 via based motherboard which was taken after quite a while in storage. When connected to the PSU, there is absolutely no power to the board. There is an led indication on the board to indicate power. This does not light up as soon as the PSU is connected and switched on.
The PSU used is a Gigabyte one. Usually in many other cases the motherboard receives power and the board won't post. However, here there seems to be no power at all. Visually I didn't notice any physical damage or burnt components. Is there anyway to troubleshoot this board?
The attachment IMG_20250521_224724.jpg is no longer available
Intel 845GEBV2, Pentium 4 2.4 Ghz, Geforce FX5600 256MB, 512MB RAM, 160GB HDD, Sound Blaster Live! SB0100 - Win 98.
Reply 1 of 14, by paradigital
Assuming the PSU is known good, it’s likely that there is either a dead short on the motherboard on one of the rails, or there’s a blown fuse.
Reply 2 of 14, by stealthjoe
The motherboard led came on twice intermittently during separate times after adjusting the ATX power connector. The board also started up on shorting the power pins. However when I switched off the PSU and back on without disturbing the ATX connector, there was no light - meaning no power.
I tested the board with a few PSUs and there was still no power to the board (led not on). Had noted 2 fuses beside the power connector and near the PS2 and usb ports. Tested these and it had continuity.
Is there anyway to test the power rails on the motherboard?
Reply 3 of 14, by Imperious
You should really get a bios post code analyser card and see what codes You get.
After a long while in storage the cpu and memory sockets might be oxidised, Clean contacts where possible.
I was in the same situation, 3 socket 370 boards that either don't work at all or lock up when operating. I purchased one of those NOS
chinese boards from Aliexpress and it's rock solid stable.
Reply 4 of 14, by stealthjoe
Imperious wrote on 2025-05-22, 00:15:
The problem is there is no input into the board in the first place. When I connect the ATX plug to the connector and switch on the PSU, the first sign of life is the motherboard light switching on. This itself does not happen.
I also tried switching on the board without this light but there was no booting possibly up due to lack of power delivery anywhere on the board.
Reply 5 of 14, by Major Jackyl
I would inspect the board very closely again, checking for damaged traces or loose soldier joints. Try pressing down on the chips/wiggle things, since you said the light flashed a few times. Could be a bad BGA?
If you can get some high-res images of the power area and the back, we could take a peep, too.
Did you ever replace B116?
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 6 of 14, by stealthjoe
Major Jackyl wrote on 2025-05-22, 01:58:
Below are the close up pics around the ATX connector:
The attachment ATX Top 2.jpeg is no longer available
The attachment ATX Top 1.jpeg is no longer available
The attachment ATX bottom.jpeg is no longer available
The attachment ATX bottom 2.jpeg is no longer available
The attachment ATX 1.jpeg is no longer available
Reply 7 of 14, by stealthjoe
The attachment Processor side.jpeg is no longer available
The B116 component was missing already when I got the board. However the board was working fine till recently.
Actually the board led lit up only twice with some adjustment to the ATX connector. However, the same did not repeat again despite multiple tries to adjust the connector.
Some more pics including the back side:
The attachment Board view 1.jpeg is no longer available
D18 is the diode which should light up first when the PSU is switched on before starting the board.
The attachment Board view 2.jpeg is no longer available
The attachment ATX Top 3.jpeg is no longer available
The attachment Board Reverse (Copy).jpeg is no longer available
Reply 8 of 14, by Excelsior
In the first picture with the whole board it seems to me that the CMOS jumper is set on 2-3 pins which means reset CMOS according to the markings on the board.
Can you check the board if is set on pins 2-3 as it appears in the picture and if this means reset CMOS?
I had a similar problem with a motherboard and I noticed later that the reason of not starting was the fact that I forgot to put set the CMOS to normal.
Once put to normal the motherboard started.
Reply 9 of 14, by Kittyboy
If it has not already been suggested, test the power supply itself too.
Pentium III 1.4GHz-S (SL6BY), Asus TUV4X, Plextor 760A, ATI 9800 Pro, MS-DOS 6.22/Win98se dual boot
Reply 10 of 14, by stealthjoe
Excelsior wrote on 2025-05-22, 07:25:
In the first picture with the whole board it seems to me that the CMOS jumper is set on 2-3 pins which means reset CMOS accordin […]
This was a troubleshooting step where I put the jumper in 2-3 position for 10 seconds and then put it in normal mode while trying to power the board. But it didn't make a difference. The main issue here is the led not lighting on the board when PSU is connected.
Reply 11 of 14, by stealthjoe
Kittyboy wrote on 2025-05-22, 07:35:
I have tried a few different PSUs but to no avail.
Reply 12 of 14, by stealthjoe
Today, I had connected the ATX connector to the board and shorted the green and black wires (paper clip test). The board started up (led lit up and CPU fan was spinning). However it didn't post nor did it allow me to switch off the board by shorting the power pins. I had to remove the paper clip short to switch off the board.
Reply 13 of 14, by bertrammatrix
stealthjoe wrote on 2025-05-21, 23:48:
If you got action while messing with the power connector you should start there.
Resolder all of the pins while heating thoroughly. It's not unheard of there being a bad connection from them to a trace on one of the inner layers, ie they could look fine on the surface but still have an issue
Reply 14 of 14, by stealthjoe
Had applied flux to the components and pins surrounding the ATX connector and heated them at a high setting (~300-400C) for a few minutes. However there was no change. Could a failed VRM could cause no power to the board? The VRM present here is HIP6021CB. The IC however physically looks fine with no signs of damage.
