LPT pico sound device?
First post, by squelch41
Looking at an opl2lpt for a 386 laptop.
Just wondering if there is a device that does this using a microcontroller like the pi pico.
Anyone know of one?
V4P895P3 VLB Motherboard AMD 486 133MHz.64mb RAM, CF 4Gb HDD,
440bx MSI 6119, modified slocket , Tualitin Celeron 1.2Ghz 256mb SD-RAM, CF 4GB HDD, FX5200 gfx
386sx 20MHz ICL NB386s laptop, 4mb RAM, modified bios with XT-IDE, CF 512mb, 387 FPU
Reply 3 of 8, by digger
I was actually thinking about something like that: a software-defined sound device like the PicoGUS or PicoMEM, but with a parallel port interface instead of an ISA interface.
With something like a Raspberry Pi Pico, it should be really cheap and relatively easy to implement, and with proper programming, it could emulate pretty much every parallel port sound/game device imaginable:
One step further than that: a more advanced variant of such a device, which would have both a parallel and a serial interface (which you would ideally plug into a both ports on a computer or laptop, through two cables). Such a device could then emulate any of the above, plus an MPU-401 MIDI interface through the serial port. This would then be compatible with the MPU-232, as well as the native RS-232 interface on some Roland MIDI modules, and would work with the SoftMPU driver. Alternatively to MPU-401 emulation, this device could perhaps also support serial mouse emulation when a USB mouse is attached to the device.
A parallel interface is even easier to interface a microcontroller with than the ISA interface, right? Just pick a microcontroller that has enough GPIO pins, wire up each I/O pin on the LPT port, use level shifters where voltage conversion is needed, hook up a high quality sound output device to the microcontroller through its I2S interface, and offer a USB port and possibly a 9-port Atari-style game port for the FTL Sound Adapter emulation, if enough GPIO pins are left for one.
And then do all the magic in software. 🙂
Full Sound Blaster and MPU-401 emulation for such a device, even in protected mode games, could be accomplished by adding support for it to SBEMU and/or VSBHDA.
Or am I missing something?
Reply 4 of 8, by digger
vic911 wrote on 2025-05-26, 05:00:
not opl, but also a sound device
I could find only this one
https://github.com/mcgurk/Covox
Oh, cool. I didn't know about that project yet. Thanks for sharing.
I wonder if the ESP32 microcontroller is powerful enough to also emulate an OPL2 or OPL3 FM synth. If so, perhaps Digispeech emulation support could be added to it as well. (OPL2 + 16-bit stereo DAC)
Reply 6 of 8, by Jo22
I think that's interesting, as a proof of concept.
On other hand, I don’t see the point of emulation.
I mean, I love emulators but when I'm tinkering with old hardware,
then I do it exactly because I want to see real hardware at work in first place.
Reply 7 of 8, by matze79
i personally dont like the put a raspi pico everywhere scheme, even if its handy for debugging things or booting quickly here it makes sense for me.
But if original ics become scarce its still a good idea.
Do you expect to source sn76489, saa1099, opl3/opl2 at cheap prices for a long time ? i guess not.
the firmware is already almost there, look at picogus, picomem with sound etc.
basicly just adress decoding needs changes and unwanted stuff stripped out also required tsr software is already here.
So at least for Chips which work with portmapped i/o, it would be not so hard to fit the pieces together.
Reply 8 of 8, by Jo22
When orignal chips (for sound etc) are nolonger available, then I'd look for functional clones.
If they're nolonger available, then I'd simply stop here (make a pause) and use an full vintage PC emulator on a PC/Mac.
Edit: I hope that the equivalent of 3D printing will eventually be available for making ICs, too.
Simple ICs from the 1970s, I mean. Which are made in microns, still.
