First post, by SonicDX
Hello everyone, I wanted to ask for help here because I don't know what to do anymore. I have these two cards, which were modified in the bios, and corrupted everything. Both cards are 64mb 128 bits. I found some bios out there on these old sites or in the archive, but some bios work, some have a black screen, but they usually cause a lot of problems. I tried to edit these bios with the bios editor, and I even managed to leave the original clocks, but both of them can never get to 64mb. They read 32mb, sometimes 16mb, but they can never read 64mb. Sometimes 128bits doesn't even work, it only reads 64bits. I tried to use HXD to edit it too, and unfortunately I couldn't. Does anyone have the bios for these two cards or could make a dump? I have already reviewed the entire board, the chips are well soldered, both work and recognize the drivers, I can play normally with them, however the amount of memory never reaches 64MB
the first model is an
ASUS V9180 VIDEO SUITE 64MB (geforce 4 MX440)
and the second is a
CHAINTHECH 64MB (geforce 2 mx400)
