Voodoo 2 gamma issue
First post, by YetAnother98dude
I run a V2 Sli setup in my system, currently with a Geforce 4 Ti. Everything works great.
But if the Voodoos are being used for rendering everything is insanely dark. Gamma is set to 1.30. If I set it to 1.70 or 1.90 it doesn't have any effect whatsoever.
In need for speed III for example it's like every race takes place at night.
Happens on both fastvoodoo 4.6 and official drivers.
PIII 1100E | ASUS P3B-F 1.03 | GeForce 4 Ti 4200 | Voodoo 2 12MB SLI | Terratec Gold 16/96 (ESS 1868f) | GUS Classic | 256MB | Win98SE
Reply 1 of 6, by Joseph_Joestar
What refresh rate are you using?
Back when I was still using a CRT monitor, gamma adjustments didn't work at 120 Hz on my Voodoo 1, so I needed to lower the refresh rate to 85 Hz or something. Might be similar with the Voodoo 2.
Reply 2 of 6, by YetAnother98dude
I'm using 85Hz for all resolutions.
I will try 60Hz and 75Hz and report back.
Reply 3 of 6, by Postman5
If you swap Voodoo2 master-slave, do the problems persist?
Reply 4 of 6, by YetAnother98dude
I did a little more testing switched the resolutions and refresh rates back and forth. The problem only occurs on 60Hz and 75Hz no matter the resolution. No issue on 85Hz and above.
Postman5 wrote on 2025-05-27, 12:31:
How? Just by plugging the VGA cable in the other card or can this be done in software?
Reply 5 of 6, by Postman5
YetAnother98dude wrote on 2025-05-27, 21:07:
physically swap the cards
Reply 6 of 6, by YetAnother98dude
That didn't work. Looks like I will just avoid 75Hz then.
