new project video card
First post, by scroeffie
iam building this video card have 1 small problem i cant find this sip resistor
if any one could help out a bit
https://github.com/hkzlab/ISA_EGA_CHIPS
Reply 1 of 16, by StriderTR
No BOM for that project yet. Fun! 😀
Personally, my goto is Mouser Electronics.
https://www.mouser.com/c/passive-components/? … 2F%20case=SIP-4
33Ohm I assume? Select that from the filters. I get 6 options from them. 😀
Retro Blog & Builds: https://theclassicgeek.blogspot.com/
3D Things: https://www.thingiverse.com/classicgeek/collections
Wallpapers & Art: https://www.deviantart.com/theclassicgeek
Reply 2 of 16, by scroeffie
thanks for trying to help but they dont have this specific sip resistor ,needs to be network paralell topology isolated
Reply 4 of 16, by scroeffie
mkarcher wrote on 2025-05-27, 22:48:
scroeffie wrote on 2025-05-27, 22:22:
In that case, what's wrong with https://www.mouser.de/ProductDetail/Bourns/46 … %2FyvTxXg%3D%3D ?
i think its the correct part but iam not shure because i never worked or used sip resistor so its all new to me
Reply 5 of 16, by digger
Oh, cool! Thanks for working on this and sharing it with the world.
Would it also be possible to add support monitors with 25kHz (or was it 24kHz?) horizontal scan, like the proprietary monitors for the Olivetti M24, AT&T 3600, etc?
The EGA Wonder 800 (without the plus) is apparently also built around a CHIPS P82C435, and supports this special mode by setting a jumper for it.
See https://www.techpowerup.com/gpu-specs/ega-wonder-800.c3180
(By the way, shame on techpowerup for excluding their site from the Internet Archive. This is historically relevant information.)
Reply 6 of 16, by scroeffie
digger wrote on 2025-05-28, 12:52:
Oh, cool! Thanks for working on this and sharing it with the world. […]
just to be clear iam not the one who made this github 😀 iam just trying to make the card for my self .the person who made it did not incl a bom file
and i dont know how to contact him so ..
Reply 7 of 16, by LSS10999
I happened to run into this bussed or isolated SIP resistor array problem on a different card that I assembled.
There were several different naming conventions for various types of resistor networks among vendors. Some vendors name isolated resistor arrays starting with B whereas bussed ones start with A, followed by 3-digit resistor values.
For isolated resistor arrays, if you really can't find the correct SIP resistor array model you can simply use individual resistors (33R in your case) by placing them in adjacent pins one by one (1-2, 3-4, 5-6, 7-8). Due to limited space, the resistors will need to be placed vertically.
Reply 8 of 16, by StriderTR
LSS10999 wrote on 2025-05-28, 16:25:
This sums it up nicely.
Bussed simply means there is a common pin among x number of resistors, where as isolated is just x number of independent resistors in a row, no common pin. I threw together an example below for the OP.
I've used independent resistors before in place of an isolated SIP before, works great. 😀
Also included an image of vertical mounted resistors since the OP said they were new to this.
Reply 9 of 16, by scroeffie
thanks for helping 😀 those chip chips are not cheap
how do you cal what the value of the resistors need to be ? 33ohms/ 4=
8.3 ohms x4=33.2 ohms ?
i orderd the correct part thanks to link from mouser but i just wanted to know for maybe the future how to calculate this
Reply 10 of 16, by mkarcher
scroeffie wrote on 2025-05-28, 18:35:
You do not calculate anything. The SIP pack you are buying is just four 33 ohm resistors next to each other conveniently put into a single case. This means there are less components you need to place on the card, and it also likely saves spaces compared to four individual resistors.
Reply 11 of 16, by StriderTR
mkarcher wrote on 2025-05-28, 18:44:
To help illustrate this...I just threw this together.
The photo below is the exact same as an isolated SIP array. The SIP array is simply smaller and more convenient. 4 resistors in a row, that's all it is. 😀
Reply 12 of 16, by scroeffie
4 resistors in a row oke but they combine together 33ohms or is each resistor 33 ohms ?
Reply 13 of 16, by mkarcher
scroeffie wrote on 2025-05-28, 22:05:
Each resistor is 33 ohms.
Reply 15 of 16, by StriderTR
A quick ebay search turns up some that claim to be NOS or just "new".
https://www.ebay.com/itm/276111096612
https://www.ebay.com/sch/i.html?_nkw=P82C435& … ksid=m570.l1313
Quite a few sources for them used. If you have to get them used, that's not generally a problem. I buy far more used IC's than NOS and it's rare I ever have issues. Buy from reputable sources and do what you can to make sure your not buying "fake" chips. eBay buyer protections help a lot with that, as does buying from sites that specializes in what you're looking for. UTSource is a good one for obsolete parts.
Reply 16 of 16, by scroeffie
i finished the project yesterday the card was working but bad graphics cut letters shaky video etc ,today i tried to reflash the eprom with another bios but i found out its not possible
with this atmel .now the card is not outputting any vid ,i think the dram 41464 is fake < ebay china ,i tried both lcd and crt
https://youtube.com/shorts/ANg6n_fNfmE
https://youtube.com/shorts/XKHwkAZpaJY
i think iam going to buy these just in case https://nl.aliexpress.com/item/10050057929743 … 7Cquery_from%3A
