First post, by LChackr
- Newbie
I have a PC with a Sound Blaster Pro 1.0. Initially MIDI playback sounded fine. Then I had a power supply fault and something clearly went wrong so I pulled the power immediately. Once I got it running again with a stable PSU I learned that the serial ports weren't working and, upon inspection, I found an I/O controller chip had visible burns on it. I hoped this was the extent of the problem since everything else seemed to be working fine ... until I played MIDI.
I discovered that playing MIDI in stereo sounds terrible. It sounds like notes are either missing or cut extremely short. If I force the SBP to work in mono, by setting it up as a Sound Blaster 1 card, the MIDI plays fine. Based on this I assume that one of the OPL2 chips might have also been damaged. Thoughts on this? Suggestions?
Thanks!
