First post, by tom10422
tom10422
Offline
Trying to run Under a Killing Moon under DosBox .63, when I attempt to set it to use the SB16, it reports device driver not found. I tried both the 8-bit DMA and the 16-bit DMA values. It detects it fine as an SBPro. The DosBox config is currently set to emulate the sb16.
Anyone have any ideas?
