First post, by EdmondDantes
- Member
I was trying to stream the CD-ROM version of Flashback: The Quest for Identity, to show off the unique CGI cutscenes that version has. When you stream, you have to run the game in a window. However, I ran into a problem in that the window kept changing size/shapes, which was not only annoying for me but messed with my streaming software (OBS).
I tried aspect=true and that minimized the problem but didn't eliminate it completely.
Does anyone have anything I could try? I checked the Dosbox wiki and found nothing about this.
Thanks in advance.
