First post, by manic232
Would someone please advise me what heat sink/fan to use for my Nvidia GeForce 4 TI 4600 GPU?
The card is in need of repair, the CAPs need changing as they are leaking, plus the fan on the stock cooler is gone, so I want to replace it with something better, but all the suggestions I see here for Zalman and other fans are no longer available.
Please can someone suggest an available cooler that would fit?
I thank you in advance.
Here are some pics.
https://www.dropbox.com/scl/fo/b72jpaza9zbvlx … t=m9zo1mcd&dl=0
My System: ASRock P4i65G MB, Win98SE, P4 2.4GHz, 512MB Ram, Nvidia GeForce 4 TI 4600, Sound Blaster Live! 5.1
Reply 1 of 6, by shevalier
What's wrong with the stock one?
When the fan blades are almost at right angles, it is a turbine. It pushes air from the center to the edge at a higher speed and pressure than a regular fan.
Turbine
Fan
It would be better to try to disassemble and lubricate the bushing.
Most likely, the impeller is simply pulled upward with some force.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 2 of 6, by dominusprog
Buy a 50x50x15mm heatsink and a 50x50mm DC fan. You can use thermal paster to permanently attach the heatsink or use 3M double-sided tape and thermal grease. You should also install small SMD heatsinks for the RAM chips.
The attachment 50x50x15mm.jpg is no longer available
The attachment 50x50mm_fan.jpg is no longer available
The attachment SMD_Heatsink.jpg is no longer available
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 3 of 6, by dm-
you can get a brand new one from japan. something like 8$ + delivery + fees
Reply 4 of 6, by manic232
dm- wrote on 2025-06-07, 14:23:
Do you have a link please dm-?
Reply 5 of 6, by manic232
Thank you for your replies. I have found a heat sink that I think will fit, https://www.amazon.co.uk/dp/B0CZ6V4FVP?ref=pp … _fed_asin_title
Now I just need to find someone to recap it for me!
