First post, by freekymachine
- Newbie
Heya.
Stumbled across this relic ;
/view Attachment [just ugly quick-pic]
Sadly it doesn't boot - Not exactly sure nor too familiar with those.
Optical = everything is fine, at least on the mainboard.
Bios = seems fine too - did read it out on other Board and made Bios-Dump + 3x refresh writes with other files from Retroweb and then back to orig one.
CPU - the one which was on it - someone did obviously remove the cooler with screwdriver and cracked the ceramic CPU - it is still in one piece, but you can bend the corner and enjoy the cracking-noises ... [...]
...but I do have a 2nd one in my collection for like 25 years, just sitting there - not sure if it works - yet why wouldnt it ?! - Did clean it, bend bit pins in order - sits perfect.
Rams - I have enough Ps/2 Rams from 4MB to 32MB spread on different Boards like Socket 8, Socket 7.
GPU - Geforce Titan XP with adapter to 16-Bit ISA (ofc...^^ - no ,3x ISA 16 Bit VGA)
Yet - Board doesnt boot - you can switch it on - Keyboard lights do flicker on for half a sec - PC-Speaker does do low crackling/static noise once when switched on - no beep or so.
CPU's do get warm - and that's it.
Do these Boards need some special parts ? GPU ? only certain type of Ram ?
Sadly ISA-Post-card is still in mail - might take a while.
Thx and greetings
